Results 1 to 10 of 10
Thread: Transmission Advice
    LXi User CzEcHy's Avatar
    Jul 2008
    89 Accord LXI
    Gulf Breeze, Florida
    Transmission Advice
    Alright, I've got hard shifting and what not in my transmission..
    It has 231xxx miles on it..
    What (minus replace), could/should I do?
    I was told adding something may make it worse, any suggestions?
    (And I just had my fluid checked and they told me it looked good)
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    Re: Transmission Advice
    when my auto started to do that , i added that motor up gear up stuff and it did improve shift quality somewhat, a 1000 miles later the trans blew up.
    perfect excuse for a manual conversion
    nfs480's Avatar
    1989 Honda Accord SE-i
    Rogers, MN, USA
    mine's been harsh shifting for the past 50,000 miles. No changes since it started.
    Just drive until it blows up. Then swap in a 5-speed and forget you ever had transmission problems.
    try to adjust the shifter linkage
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Use honda fluid.
    CARDONE SUCKS.
    DX User Cody's Avatar
    Dec 2007
    1987 Accord Si 2.0 manual + transient population of other cars lol
    Sydney Ausralia
    according to the manufacturer you should be using engine oil, but according to every oil company, you should be using around 75w80 oil as they sort of suggest for every car of that age.
    Honda does make a transmission fluid but that only came out once they released the s2000, but that might be a bit of overkill.
    Theres heaps of treatments on the market, you should try some, they cant really put your box in much more worse condition than it is.
    Quote Originally Posted by LX-incredible View Post
    Use honda fluid.
    yes or use a synthetic additive to dexII
    also over time as your car drifts out of tune... gradually the accuracy of the TV cable adjustment goes out thus affecting shift quality and points.
    Try adjusting the TV cable just a tiny bit.
    LXi User headbanger's Avatar
    Dec 2007
    1989 accord lxi
    waynesville,nc
    mine was doing the same thing in my lxi.So I swapped tranny and it still did it I adjusted tv cable a little bit an it helps but do it in small incrments an drive car to make sure cause it dont take but 1 turn to far 1 way or the other to make it not work properly.I have to readjust mine cause I got shifting a lil better but now there is no lockup.
    ^^^needs a hair more, also make sure it is all lubricated good and the cable housing under the hood is not attached to the other cables, any movement could disrupt the tv lever slightly.
    Also check it is pulled up good and lubed at the gas pedal.
  1. Advice
    By CzEcHy in forum 3geez Accords
    Last Post: 02-23-2012, 02:28 PM
  2. B20A transmission advice - yes I've searched!
    By zedries in forum JDM B18A / B20A Swap Tech
    Last Post: 03-09-2011, 05:15 AM
  3. Need an advice!
    By Trienlysleeks in forum 2geez Accords
    Last Post: 02-28-2009, 10:18 PM
  4. some advice
    By accordlxi2.0 in forum Classic Honda Community Chat
    Last Post: 04-22-2004, 05:11 PM
  5. New around here could use some advice.
    By serv_o in forum Carburetor Tech
    Last Post: 02-16-2004, 05:58 PM
