Results 1 to 19 of 19
Thread: what could cause the car to sit a little uneven
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    i think my car is sitting a little higher on one side than the other, what could cause this?
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Re: what could cause the car to sit a little uneven
    It's either sitting higher on one side or it is not? (don't get me?? nvrmind )
    Anyways, mine does sit higher on the right side because of my left suspension (broken springs, bad struts). Too much hard right corners, not enough lefts.
    89 Accord LX Coupe
    Vernon BC CANADA
    hahhaha.....then start cornereing left more..Anchovies..
    OR else its just that you have been driving it and the weight is settled to the one side..bounce it a bit and see if it settles even..
    otherwise check the springs and shocks..
    BEn
    Oct 2001
    87 Accord EX , 5spd , Manual
    i think it's relative to many other things ! i shouldn't worry if i were you !
    MIKE
    97 Dodge Neon
    Athens AL
    i got the car lowered sometime in july, maybe its still settling? how long does it usually take for springs to fully settle??
    SEi User jigga225's Avatar
    Louisiana
    look at the motor... its a little more on the driver side right...............
    Banned
    Morgantown, West Virginia
    Maybe your a fat ass
    Nate.
    97 Dodge Neon
    Athens AL
    lol nah im not a fat ass,
    hey the engine is a little more on the right side, and my car looks lower on the right side, could that be the reason?? how can i fix this??
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    mmmm...move the engine..
    I don't think the slight placement of the engine matters nonetheless. The suspension "should" sit balanced. I should shut up now, mine is not balanced
    LXi User InfinityAudioLXi's Avatar
    '86 Ford Bronco II XLT, 1989 Honda Accord LXi Sedan
    Baghdad for now
    just have a fatty ass sit on the opposite side! oh, by the way Nate u crak me up because i was thinking the same damn thing
    Save a Tree, Wipe ur A$$ with an Owl!
    Don't Drink & Drive, You Might Hit A Bump and Spill it!
    Banned
    Fat hairy kids with glasses scare me..
    Nate.
    Jdub07's Avatar
    1986 Honda Accord DX Hatchback
    Newark, CA
    check your tire pressure
    86 accord dx wrecked
    97 Dodge Neon
    Athens AL
    yea im gonna check that today, i know the back ires have uneven pressure the the fronts are good.
    ill fix that and see if it evens out a little
    97 Dodge Neon
    Athens AL
    it helped a little but still uneven
    Louisiana
    man everybody's car sits uneven stock.
    Thats what I was tryinn to get u to see .
    The driver side is a lil lower
    LXi User Chrome_thangs's Avatar
    1989 Honda Accord LXi Coupe
    That dirty south!! Columbus Ga.
    I dropped my car about two months ago and it still sits a little uneven too. To balance it out I put about 80 pds of weights (the weight lifting disc kind) under the passenger seat and in the trunk on that side. I of course, remove them when i have a passenger. Ya, i know that sounds stupid but it works!
    97 Dodge Neon
    Athens AL
    man this is gay why didnt i find this shit out before i lowered my car, thanx anyways guys
    88 Lxi/ 5spd
    Tennessee
    ok a quick and easy fix would be to jack up one side and twist the spring around in its perch. You could have a worn strut on one side but since you just lowered it I would say mess with your springs a bit. You know the litte indention on the bottom plate?....well scoot the end of the spring around and you can actually make it sit +/- .5 inch higher or lower
    In the end...it doesn't even matter.
    88 Lxi, 5spd swap w/ Aasco 8lb flywheel/Cai,AccelCoil,NologyWires,SilverstoneSparks/DC421,ColtCam,Remachined Head&Tb...NitrousWorks 40shot
    97 Dodge Neon
    Athens AL
    ah ok i will check it out tommorow morning, so i can set it to lower than usual?
  1. Uneven idleing on '88 Accord
    By MysilB in forum 3geez Accords
    Last Post: 01-08-2009, 05:51 AM
  2. uneven ride height?
    By FlySquid in forum Classic Honda Community Chat
    Last Post: 05-23-2002, 12:02 PM
