Results 1 to 6 of 6
Thread: Speedometer concern
    Dec 2003
    Millington, TN
    Speedometer concern
    Was using the Garmin gps and noticed the speedometer didn't match the Garmin speed. It matches the Tundra perfectly so I'm sure the speedometer on the car is out of whack. Its off by 8.
    73mph = 65mph
    Phil
    Re: Speedometer concern
    Hondas typically read fast. I don't know why, both of mine do that, and like 4 or 5 of my friend's Hondas do and so does my Miata even. Usually it's 4-5mph assuming you're running stock size tires, if you have different size tires, that will change as well. You could take it to a speedometer shop and probably get it adjusted, but is it really worth it?
    Dec 2003
    Millington, TN
    No, not worth it no that I know what the difference is I can adjust for it. Thanks for the input.
    Phil
    you still run stock sized tires? mine changed a bit when i put some 205-50s
    random, my speedo says i'm doing 90kph when i'm actually doing around 100kph (dunno about now as i have just swapped gauges) and that's with wheels smaller than stock size on my car
    Dec 2003
    Millington, TN
    Original tires.
    Phil
  1. Little concern with transmission
    By New3rdGenOwner in forum 3geez Accords
    Last Post: 03-12-2008, 01:32 PM
  2. Not a big concern, just wondering
    By accord newbie in forum EFI Tech
    Last Post: 05-13-2005, 07:20 AM
  3. Could This Be Reason For Concern?
    By it's paid for in forum 3geez Accords
    Last Post: 02-07-2004, 09:06 AM
  4. Lowering Concern
    By 1989se-i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-12-2002, 09:40 PM
