Results 1 to 8 of 8
Thread: Fuel Issue
    May 2009
    Fuel Issue
    I got an 86 lxi with 340,000 miles on it. It starts and drives pretty good but hesitates and sputters under any load. At higher speeds the PGM-FI light comes on. When this happens the idle starts to jump from 1100 to 1800 when not moving. But the strange thing is if I kill the motor and start it again the symptoms are gone and the light wont come back on for a while. I put on a new filter, fuel pressure regulator, fuel pump relay, fuel injector resistors and such. I have not looked at the pump yet. But I pulled each of the injector wires individually and felt a drop in idle for each one. And sometimes the battery light will flash when its cold in the mornings. But that might be a different issue.
    May 2009
    Re: Fuel Issue
    I've heard that you can preform whats called a paperclip test. Jump two terminals on a diagnostic connector somewhere and get the PGM light to blink out a code. Is there anyone who knows anything about this proceedure? Is it even possible on my model?
    SEi User turabaka's Avatar
    Aug 2007
    Boise, ID
    Re: Fuel Issue
    I believe there's a diagnostic light attached to the ecu under the drivers seat. That's the light that blinks the code. Hopefully one of the fuel injected guys can chime in since I don't even have an ecu in my car.
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Re: Fuel Issue
    Yes turbaka is right. Take out your driver's seat and you will see the ecu bolted to the floor. Get yourself a Chilton's Manual and locate the ecu codes. Now just turn the key to the on position (don't start the car) while looking at the ecu and observe the number of flashes you see. Then refer the number of flashes to the code in the manual. Note: Sometimes you mave have more than one code
    LX User Bluntman's Avatar
    Apr 2009
    1988 Honda Accord LXI
    Orange County Cal.
    Re: Fuel Issue
    This will help.
    Comment posted on Jul 01, 2008
    How to check your Check Engine Light codes:
    1. move driver seat all the way forward.
    2. locate the box on the floor.
    3. locate the small plastic window and pop it open.
    4. turn the ignition on.
    5. count how many times the light blinks.
    6. refer to the table below
    CODES for 86-89 accord and 85-89 prelude
    00 LED FLASH(s) ECU
    01 LED FLASH(s) 85-98 Accord
    Oxygen Sensor "A" (Primary)
    defective circuit or unplugged / defective sensor
    02 LED FLASH(s) 85-89 Accord
    Oxygen Sensor "B"
    03 LED FLASH(s) 85-98 Accord
    MAP Sensor (Manifold Absolute Pressure)
    04 LED FLASH(s) Crank Angle
    05 LED FLASH(s) 85-98 * Accord
    mechanical problem / disconnected piping
    * exc. 94-95
    06 LED FLASH(s) 85-98 Accord
    ECT Sensor (Engine Coolant Temperature)
    07 LED FLASH(s) 85-98 Accord
    TP Sensor (Throttle Position)
    08 LED FLASH(s) 85-98 Accord
    TDC Sensor (Top Dead Center)
    09* LED FLASH(s) 85-98** Accord
    CYP Sensor (Cylinder)
    * not a valid code for any throttle body injection Hondas
    ** not a valid code for V-6 engines
    10 LED FLASH(s) 85-98 Accord
    IAT Sensor (Intake Air Temperature)
    12 LED FLASH(s) 85-98 Accord
    EGR Lift Sensor (Exhaust Gas Recirculation)
    13 LED FLASH(s) 85-98 Accord
    BARO Sensor (Atmospheric Pressure)
    14 LED FLASH(s) 88-98 Accord
    IAC Valve (Idle Air Control)
    IAC VALVE HELP
    15 LED FLASH(s) Ignition output signal
    16 LED FLASH(s) fuel injector
    17 LED FLASH(s) 88-98 Accord
    VSS (Vehicle Speed Sensor)
    Thanks to my buddies at 3geez for the info, When That check engine light comes on bring the car to a stop DONT TURN IT OFF! and follow the instructions Posted above That WILL Narrow it to the the Exact problem. Good Luck Man!
    May 2009
    Re: Fuel Issue
    Okay so I checked the light and it was 12 flashes. I figured this meant it was an EGR valve problem and swapped it out. But after a few miles on the free way the light came back on showing the same code. Any suggestions?
    May 2008
    los angeles
    Re: Fuel Issue
    Quote Originally Posted by 86lxi340K View Post
    check the wiring.. the plastic wire cover can be cracked or could be grounding out somewhere
    -Tom
    1988 4 Door Lx-i 5-speed
    364,XXX and counting :]
    Re: Fuel Issue
    Take a handheld vacuum pump and apply vacuum to the valve with the car running. The car should shut off. If it doesn't, then I would look at the ports in the intake. Clean them out and see if that helps. If it does, then I would check the control pots in the black box.
  1. fuel issue? What is this sensor?
    By kentwat in forum EFI Tech
    Last Post: 02-09-2012, 06:03 AM
  2. fuel issue... help?
    By 1987AccordLx-i in forum 3geez Accords
    Last Post: 07-15-2009, 11:56 PM
  3. Fuel Delivery issue?
    By mountain_geez in forum Carburetor Tech
    Last Post: 05-25-2009, 07:40 PM
  4. B20A fuel issue
    By bullard123 in forum JDM B18A / B20A Swap Tech
    Last Post: 11-08-2008, 10:17 AM
  5. no fuel issue
    By honda-ski-86 in forum EFI Tech
    Last Post: 05-21-2005, 06:27 AM
