Please I need some help before I drvie this accord off a cliff into a deep deep lake somewhere.
Ok.
When I bought this car it idled way to high the woman I bought it from said it had an intake gasket leak.But I got car to idle down without replace intake gasket.But it wouldnt idle when you started it cold.Once it warmed up it would idle at about 2000 rpm way to high but better than it was at like 3500 rpm.I sprayed carb cleaner all around intake an carb base didnt find any leaks.
So I replaced carb with three different ones I finally got one that the choke unloader worked right on.But it will not idle down where its suppose to it wont idle at all when its cold started.Once it warms up it was idling at about 1500 rpm but today all of a sudden it wont idle at all.When you let off gas pedal it drops straight down to 0 an dies.Please please help me if you can I really like this car Ive fixed all its little problems but this one.And it is driving me batty everytime I stop at a light I have to mash in clutch,hit brake an keep it reving all at the same time.Also if I turn idle stop screw I can get it to hold fairly constant at 2000 rpms but if I try to go below that it starts getting erratic an eventually will die.
