Results 1 to 18 of 18
Thread: car wont start all of a sudden
    LX User geeteedan's Avatar
    Jan 2009
    89 Accord LXI
    Greensboro, NC
    was fine yesterday and the whole weekend before with no problems
    went to start it today to refill the ac and now it wont crank. It tries to but wont
    ive checked the fuse under the dash and its fine. stumped
    Current DD
    06 Acura TSX
    89 Accord LXI, 259k miles and counting
    98 Mustang GT weekend car
    Jan 2009
    89 Accord LXI
    Greensboro, NC
    Re: car wont start all of a sudden
    edit: upon searching i hope its not the main relay
    Current DD
    06 Acura TSX
    Jan 2009
    89 Accord LXI
    Greensboro, NC
    well rolled the windows down for a little while and let some fresh air in for about 10 minutes and what do ya know, car started right up. So if it is the main relay, how hard a swap is it? My local stealership has one for $67
    Current DD
    06 Acura TSX
    conozo's Avatar
    Fort Wayne, Indiana
    Its not hard to resolder once its out, but it would help if your elbow was 3 inches from your rist to get at it.
    1988 Honda Accord LSDX-I
    Joay's Avatar
    Sep 2008
    Misty Beige 1988 LXi Coupe
    The hard part is getting to it, cause it's kind of jammed up under the dash. Once you get there, it takes all of thirty seconds.
    Jan 2009
    89 Accord LXI
    Greensboro, NC
    napa carry them or is $67 + tax my only option?
    i wouldnt know thr first thing about resoldering
    Current DD
    06 Acura TSX
    DX User TsubohachiLX-i's Avatar
    May 2009
    1987 Honda Accord LX-i Sedan
    Dallas, TX
    When you turn the ignition to ON mode, you should hear 2 CLICKS come from your foot (if the clicks are strong enough, you should FEEL them). If you do not hear those clicks, then it IS your Main Relay. Also, be sure to listen BEHIND YOU as well, because the Main Relay also activates the FUEL PUMP (the pump makes a humming noise). This happened to me last year.....
    You can always tell when the Main Relay or Fuel Pump is going bad, because sometimes they'll work and somtimes they won't......it helps to listen for the sound........
    Once you replace the Main Relay, just kind of leave it hanging near the floor, or prop it on the carpet so it won't be so hard to reach it next time.....
    SE-i Sedan 5 spd
    There's a couple of suspects in the "crank but won't start" category. First is the infamous Main Relay. If yours hasn't failed, it will eventually, so you might as well deal with it. You don't have to buy a new one, although I did, but that's just me. The problem is micro-cracks in the solder joints, which need to be resoldered. The other problem is access.
    See message #2 in this thread, about tapping on the relay for a possible emergency fix:
    https://www.3geez.com/forum/showthread.php?t=61988
    And if you want to read my adventures with the relay, message #1 in this thread:
    https://www.3geez.com/forum/showthread.php?t=61773
    You don't have to do what I did to get at the relay. You can drop the fuse block (so say others).
    If you'll read my posts referenced above, you'll see that I couldn't get enough of a swing on my ratchet to remove the bolt holding the relay in. As a result, I bought this tool. Haven't used it yet, but it would have made getting the relay out pretty easy I think. $29.95 at Home Depot.
    https://www.3geez.com/forum/showthrea...ighlight=husky
    The other suspect is the TW sensor, about $20 at the dealer. Located by the thermostat, if it's failing, you'll get 6 flashes on the box under the drivers seat, and eventually the car won't start. Again, it will fail eventually, so you might want to put a new one in anyway.
    GL
    Jan 2009
    89 Accord LXI
    Greensboro, NC
    Quote Originally Posted by w261w261 View Post
    The other suspect is the TW sensor, about $20 at the dealer. If it's failing, you'll get 6 flashes on the box under the drivers seat, and eventually the car won't start. Again, it will fail eventually, so you might want to put a new one in anyway.
    GL
    i'll check the box in the morning to see if im getting anything there
    thanks
    Current DD
    06 Acura TSX
    May 2009
    87 Honda Accord LX
    Pinetop, AZ
    Salvage yard will have them I would bet. I found a few of them along with the carbed ones I needed for 2 bucks each. To bad I could only find 2 of each type. I know it fixed the problems on 2 of my cars. At least call them and see how much they'd charge for a relay from the accord or what not and don't use the word "main" for the relay lol.
    OFC if you have the ability to solder and such I'd do it that way cause free fix is better then 2 bucks. (buy a few spares if they're as cheap as I got them)
    Jan 2009
    89 Accord LXI
    Greensboro, NC
    ok, im getting ticked off at my self.....
    I have spent the last 30 minutes trying to even find the relay and i cant see crap up there
    Current DD
    06 Acura TSX
    Joay's Avatar
    Sep 2008
    It's on the driver's side right up against the fender. It helps to take out the fuse box, if you take out the coin thinger you can see the relay behind it with a flashlight.
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    I managed to pop the connector off of the stock one and just plugged the new one in.
    It's ziptied down, but it was too much effort to remove the dead one.
    SE-i Sedan 5 spd
    Wuss! Yuk yuk
    SE-i Sedan 5 spd
    Quote Originally Posted by geeteedan View Post
    This main relay replacement is like a Hell Week for 3G owners. The rest of the car is so straightforward and generally pleasant, that is comes as a surprise (at least to me) that the main relay is where it is, and is such a PITA to replace.
    I couldn't find it either, that's why I wrote this, which was referenced in an earlier post in this thread:
    <Open and remove the coin drawer on the left side of the dash. Look in with a flashlight and see the main relay up on the left. It's a black box a couple of inches square with the coupling going into the bottom of it...if I recall the coupling is white.>
    You still can't find it? Look harder!
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Wuss! Yuk yuk
    Not denying it.
    take the front seat out first saves time in the long run
    DX User 88Lxi Guy's Avatar
    May 2009
    88 Accord Lxi
    Louisville,Ky
    you probably have a bad distributor coil.
    There are 8 nuts on a Honda it only takes 2 to win the race.
  1. 86 accord start then died then wont start again
    By khmerproduction in forum 3geez Accords
    Last Post: 02-03-2006, 08:07 AM
  2. Help! Car wont start
    By nappyroots827 in forum Performance
    Last Post: 10-11-2004, 07:45 PM
  3. 87 LX-i wont start...need help
    By whyterice in forum 3geez Accords
    Last Post: 02-08-2004, 09:20 PM
  4. Car wont start...
    By Crazee3g in forum 3geez Accords
    Last Post: 12-31-2003, 04:05 PM
  5. Wont Start
    By jonzer77 in forum 3geez Accords
    Last Post: 12-12-2003, 03:33 PM
