Page 4 of 8 FirstFirst 12345678 LastLast
Results 76 to 100 of 194
Thread: HOW TO: DIY catch can
  1. #76
    Re: HOW TO: DIY catch can
    Quote Originally Posted by 'A20A3' View Post
    89T - yes i did notice a increase in fuel mileage. but the oil staying cleaner longer made me more happy than the mpg haha
    my can is vented, it's run from the metal hose line off the back of the oil pan(the one that used to have the little rubber hose on it that went to the black box) up to the catch can. i left the black box on the motor, but its been cleaned out with gumcutter as to prevent any of that nasty old sludge to come out all over the place. the only thing that really pisses me off, is that the fitting coming off the oil pan is at such a shitty angle for running a line. theres little clearance from the driver side axle. it took me 2 hose clamps(tightened to DEATH) and a bunch of "persuasion" to make it leak free.
    i still need to drill a extra hole in it so i can run the line from my vlave cover to it as well. i don't want to recirculate any of this shit anymore. it's not beneficial to the motor. period.
    all i needed to know. Ill be doing this soon.
  2. #77
    I have a couple empty cylinders laying around. I need to get off my ass make one and do my Vac removal at the same time.
    And than figure out how to hook up the catch can
  3. #78
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    rendon, am i crazy or is your car missing the IACV on the intake manifold?
    -Harvey
  4. #79
    I have clean oil with stock stuff.
  5. #80
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    you don't have to worry about oil getting up to the can either. mount the can up high, and as far away as possible. mines on the firewall. and i've never had anything come out the drain when i open it.
    -Harvey
  6. #81
    89T's Avatar
    Apr 2004
    we will be here when you'r ready.
    un-motivated!
    3GR
  7. #82
    ^^ sweet. i prob wouldnt even put a drain. But i do plan on making something cool for it haha. p.s. u have a pic of urs on here?
  8. #83
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    it's the only pic i have right now. but you can see the crazy angle i had to run the line, just so i could not get in the way of the axle, and not kink the line going to the can. it kinda loops around and gently sits on top of the master cylinder cap.
    -Harvey
  9. #84
    well damn thats a bitch. might just have the hose cut and re-welded when i tap the oil pan...
  10. #85
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    ehh..it's not that bad.
    but if you have the tools and resources and time, then remove the pan, baffle it, and re-do the line for the can, and then re-install it.
    -Harvey
  11. #86
    ah so u dont have teh return line and just capped the manifold right? thats the way ima hook mine up
  12. #87
    looks good. now take it off and paint it to match the car.
    If you wanted to you could add another fitting for the crank case.
    ti
    Yeah i have to do that...ill prolly do it black...i dont like mix match shit lol
    rendon, how would you rate it to make? 1-5.... 1 easy 5 hard?
    Well for me it was easy...as long you have a step bit which was 14 bucks and a the right tools...i had a boring bit and a vise....i didnt have a flaring to but i used the boring bit to smooth it out...i say a 2. maybe 3 but if you not skilled in making nothing maybe a 5...But i know for me and you it was a 1 lol
    Thanks once again bro for making a such legit catch can. ANd now i dont have to worry as much lol...looks alot better the the nos status can.
    Took that shit off yo...didnt make a difference but a crap start up in the morning when its cold...but takes a couple of taps and shes at 2 at start up lol
    89T's Avatar
    Apr 2004
    ti
    Yeah i have to do that...ill prolly do it black...i don't like mix match shit lol
    Well for me it was easy...as long you have a step bit which was 14 bucks and a the right tools...i had a boring bit and a vise....i didn't have a flaring to but i used the boring bit to smooth it out...i say a 2. maybe 3 but if you not skilled in making nothing maybe a 5...But i know for me and you it was a 1 lol
    Thanks once again bro for making a such legit catch can. And now i don't have to worry as much lol...looks allot better the the nos status can.
    let me know how it works for you, mine has been working fine so far.
    This has turned out to be a pretty good Thread.
    un-motivated!
    3GR
  15. #90
    I would do it pico...more legit setup. Isnt that hard at all
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    this is a good thread. +1
    -Harvey
  17. #92
    x2
  18. #93
    bridgewater.NS Canada
    So can I run one to the oil pan and one to valve cover or won't that work.
  19. #94
    yay i just got done making one!!
  20. #95
    No. LOL...you have to have a catch can if you want to do that
    89T's Avatar
    Apr 2004
    what i think he meant was run one line from the catch can to vc and the other to the black box or tube.
    the answer :yes you can.
    un-motivated!
    3GR
  22. #97
    89T's Avatar
    Apr 2004
    pic?
    un-motivated!
    3GR
  23. #98
    x2
    just installed mine and have a question.. do i keep the pcv valve? or do i just remove it and run the line straight to the box.
    and the epoxy did not get along with my paint and the paint chiped off the in aera.. but there are no leaks i vac tested the can lol ima put some jb weld around the bung anyway though when i add another one for the valve cover (currently have the valve cover ran in to the intake) and yes i do need a vaccum cap for the manifold will get one tomarrow
    http://s242.photobucket.com/albums/f.../catch-can-y0/
    EDIT:
    top 4 pics are the finished pics for the night
    and i decided to run the line from the oil separator straight to the catch can without pcv valve... and im going to add another bung to the catch can and add the valve cover line to it, also going to get some vac caps since the hoses with the bolt in it are gay lol
  25. #100
    you can remove it bro....looks hella good.
    I went for a drive and almost got high and why cuz my gurl wouldnt open her damn window...i hit full boost and i get some smoke not alot but some and im like fuck i started smelling it so after awhile im like shit...SO i open the window and no more smelly im like thank go...then she rolls the bitch back up lol...wtf.
    Anywho it works...didnt catch much..you see some but not shit ....very affective for sure...alot better then my old setup.
  1. DIY oil catch 'can'
    By NXRacer in forum Performance
    Last Post: 08-04-2017, 03:57 PM
  2. [Engine & Transmission] HOW TO: DIY Catch Can
    By 89T in forum How To
    Last Post: 05-29-2009, 07:10 PM
  3. do it youself DIY oil catch can
    By SQ is the SQUAD in forum Performance
    Last Post: 02-26-2005, 03:32 PM
  4. FREEEBIE! with a catch
    By Jdub07 in forum Trading Post
    Last Post: 01-14-2004, 01:23 PM
