Can anyone answere me please on the right way to do this.
you can take the valve outta the black box, or leave it.
But you run one line to the valve cover, one to the black box and both go to the vented catch can.
OR
you run one line to the vc, one to the black box, and one from the catch can to the intake with no vent filter.
Thank you,the valve is in the black box behind the motor with the hose attached to the oil pan .thats what your talking about right.
What do i do with the pcv opening and seperator hose connections ,do i have to plug them or can i just leave them alone.
bump!
ttt
un-motivated!
3GR
nevermind.
Opp
un-motivated!
3GR
mine leaks. its really annoying. I think all my pressure is spraying outta the bottom hose. So what im thinking is that the bottom is the oil return to the pan once it gets separated. i wanna plug where the black box goes. anyone know what size the hole on the block is? I need a freeze plug for it lol.
I think that was a blow by issue heheh
Can you ditch the black breather box and hook it to the oil pan or not.
Did you weld on a smaller tube or did you use bigger hose.
I think i used a 3/4' hose.(?)
It's been a minute and I have not put it back on yet.
i need to make cah catch can part 2! gonna go with a sealed one this time and run it to the intake manifold need one pretty bad on the accord getting a shit ton of oil in my intake and intake manifold
http://www.ej8squad.com/thread-9184.html
good idea of what my next one will be likeexcept the pcv line will also be connected and the return line will be ran to intake manifold
Hey guys if i remove the breather box,what do you use to plug the hole in the block?
freeze plug.
un-motivated!
3GR
Anyone know what size.
I'll let you know.
un-motivated!
3GR
sticky please!
I've tried.
un-motivated!
3GR
