Page 5 of 8 FirstFirst 12345678 LastLast
Results 101 to 125 of 197
Thread: Tomisimo's Black.87.Sedan B20a Build Thread
  1. #101
    a pile of lawn ornaments
    Newtown, CT
    Re: My B20a Black Accord Build Thread
    nah man I'm just playing. I have some clothes designated for 'garage clothes' and they all look like that if not worse.
    Keep up the work man, you're right there, just need to button up a few small things and she's off to the races.
    -Mark D.
  2. #102
    hope that a20 does not let you down
    Well, I'm glad you made some progress on your car! At least the starter turns over now. Now if it's not starting, back to the basics, fuel and spark.
  4. #104
    Newtown, CT
    except not only does it start, but it runs. So fuel and spark should be good. I'm pointing my finger at electrical.
    -Mark D.
  5. #105
    Oh it runs now? Well what's wrong then?
  6. #106
    he said it wont turn on from the ignition
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Yes the engine runs, only timing is off. need to find that sweet spot.
    But yes it want start with the ignition key. Still no Idea what could cause the problem. My last reserve is to run direct wire from ignition key to starter motor.
    My Build Thread
  8. #108
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    I guess its time for a little update here.. Been busy last 2 weeks so didnt had the time to work on it until now..
    So far done, Engine tuned, timing is spot on now.
    Changed shocks, now its 50/40mm lowered.. looks sexy
    figured around my starting problem. I bypassed tru switch.
    and some other mix stuff, havent driven her yet but I plan on it today.
    Well here are some pics.
    Guess what this is for? You guest it, its a starter switch. Works only when key is on 2 position. I used headlamps washer button.
    my very short shift
    I had to rice her up a bit with these
    and I LoL'd at this
    Well I still have to take her for a spin and wash her and will be doing a photoshoot, I find my neighborhood boring for pics.
    My Build Thread
  9. #109
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    God I missed my car, here is why
    goes lik a bullet, it refuse to go under 90km/h or 55 in your terms.
    Well I tried to drive, film and shift gears at once so dont be scared when it seems and sounds like I'm of the road and crushed and 3geezus came down for me.. lol
    http://www.youtube.com/watch?v=I9G--QQsRFE
    and my start button..
    http://www.youtube.com/watch?v=NiOsmRb5Htc
    I love this thing.. like a little boy, was plaing all day with it..
    My Build Thread
  10. #110
    Nafs Asdf's Avatar
    Feb 2008
    Finland
    Nice!
    Love that starter button, kinda works like an anti-theft device too if you don't know it's there.
    Yeah you need to get some more pics up when you wash it, and lol at the Kiwi rush rims.
  11. #111
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    I guess I add it here.. I had my spark plug broken inside the head, BAD LUCK I say, but nothing to worry about, have to fix that now. How I dont really sure yet. I have 3 options
    *1 Change the head
    *2 bore it out (but glass chips will fall inside, need take the head off anyway)
    *3 Weld a Nut on it and try.
    Well Thats what shady mechanics do when they f*ck threads inside the head and dont tall you about it. I never changed plugs on this engine so its not me who broke threads, that caused that madness and nightmares for me.
    here is pics
    see on the second pic? those threads are also ruined so, need to be careful as I dont have Hali-Coil to retread it again..
    And its part a bad design to the head from honda, as Cylinder one has less space to reach to the plug than other 3 do. As you all know, its 2 types of Spark Plug design, one use small nut, the other use big nut. Well those heads designed for small type. and I bout big Nut type plugs..
    My Build Thread
  12. #112
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Well lill update here..
    I have a power lose in corners and hard braking, I found out why.. Well my Gas filler tube is rusted and there is good deal of rust inside the tank, I few days ago swapped fule pump from my parts car and now its full with rust particles. and I drained all gas out the tank and find thick layer of mud there.. it sucks as Now I have to swap out tanks. what a bitch job that is.. lots of tubes and hoses. but anyhow. Pics will be later. today..
    My Build Thread
  13. #113
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Take a tour in my gas tank..
    Here an old Fuel pump
    New fuel pump (after 2 days inside)
    Inside the tank
    and that is why, inside filler tube is rusted
    and someone found that it will be good idea to mold it in fiberglass..
    Now If I touch it I need to mold it or weld it.. Well I dont have any choice but to mold it as I dont have new panels and welding machine here..
    My Build Thread
  14. #114
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    ^^^ Yikes, thats kind of scary... lots of rust there... not such a good thing in the fuel system.... I would imagine you will also want to change your fuel filter after you change that out too.
  15. #115
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Yes will do that too.. only problem now is to take down the tank.. there are just to much hoses and clams, dont want to cut anything..
    will be ordering new fuel filter and change that also..
    My Build Thread
  16. #116
    Ichiban's Avatar
    North of You.
    There's lots of water in there. Time to flush the tank out well, and maybe re-evaluate your gas station.
    ICHIBAN!
    "Now, even more better!"
  17. #117
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Done som progress today..
    took down Gas tank off my Gray Accord with filler tube, cleaned it and resprayed with the Tank.
    Before
    After
    took some time to get old tank out mostly because all bolts were so rusted that I had to use undersize wrenches to unbolt them.
    see^^ the mount rotten away.
    Then I cleaned under lid, got rid off old filler and resprayed it, masked from behind and will be filling it out later with more body filer. Have no choice but to do this. Will be redoing this later on, when I go loose on rust.
    My Build Thread
  18. #118
    very nice man.....clean work
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Out with old, Inn withe new
    It makes me smile just to look at it!!
    Ouh and I also scraped rust with metal brush and sprayed it over with black, just to keep moisture out for few more months. as you all know that when rust gets thick it keep moisture inside longer and there by rust more..
    Dont have finish pictures but progress is here
    My Build Thread
  20. #120
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    thanks Randon, I try to be that way
    My Build Thread
  21. #121
    carotman's Avatar
    Montreal South Shore
    You can get a replacement fuel filler area directly from Honda. They're cheap too. You just need to remove the old one and glue the new one in.
  22. #122
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    ^^Unfortunately replacing it is not that easy though since it is in between the quarter panel and the inner fender and there are also welds holding it to the quarter panel. It is easiest to do if you are replacing the quarter panel at the same time.
    Tom, werent the 2 bolts holding the tank straps a cunt to remove? They always tend to be so rusted that they snap when you start turning the nuts. I hate those 2 bolts lol.
    Good thing you got the other fuel tank mounted. Looks like you've been playing around with a rear wheel arch replacement panel on that left side? Or is the marker scratch just an accident?
    Link to my 3geez garage
  23. #123
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Yes, I was looking to get that, but my problem is that I need to replace whole quarter panel anyways, my wheel arches are gone, its nothing more than body filler hold those looks.. and inner fender will be needing to be replaced as well.
    What I was thinking to do is to use liquid metal filler with my fingers, first thin layer, let it harden, then again and again to build a wall, not to much not to little. and I will use my spare engine nuts that are rounded on top to cover those 3 bolts there.. and dont fill over them like it was before. I will need those later, so filler dont going to go over the edge but to the edge.
    Problem begore was that the filler tube was holding to rubber hoses at the tank side and filler under the lid, because mount was rotten away, but now its stands firm and really I dont need to fill anything, I will do that simply cosmetic and to keep moisture out and gas to sip under the wheelarch..
    My Build Thread
  24. #124
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Quote Originally Posted by thegreatdane View Post
    Indeed Marthin, luckily on my gray accort there was so much protective oil there that rust didnt got to those, but on this Black one I snapped one on drivers side, so I replaced it with from my gray car, and I lube those good begore turning. but the left side was stubern and snapped.. But I did have bent that hole that that long bolt slides in, on both sides.
    And no, that wasnt me playing with that left quarter panel, it was previous owner that left masking tape edges.. I was thinking to wet sand it and respray it like it sud be and clear on top and wet sand it again mo blend it in abit.. both sides are like this
    My Build Thread
  25. #125
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    I had to move so I pack my things and moved out of my apartment, but luckily I cud rent a wood house to store my thing as I cant take everything with me..
    Here is the engine, I moved it inside, for a bitch job that is to lift that 220kilo engine inside all by my self.
    And they came for my car.. R.I.P my beloved Accord
    You can see that rear crossmember with everything is loose, I kept it, Will be swapping it on my Black accord, and front assembly as well. Engine bay cleaned out of all wires, motors, hoses and stuff, completely stripped down. Well only brown interior and coupe wiring that was left in it...
    My Build Thread
  1. Hash_man_se_i's 1988 EX-i sedan build
    By Hash_man_Se_i in forum Project Central
    Last Post: 12-11-2019, 05:44 PM
  2. 87 lx accord sedan build
    By ab1993 in forum Performance
    Last Post: 05-30-2012, 01:45 AM
  3. Rendon Lx-I Boosted Sedan Build
    By Rendon LX-i in forum Classic Honda Pics & Videos
    Last Post: 07-27-2011, 12:15 PM
  4. Lx-i's 88' LX-i Sedan DD Build
    By LX-i in forum Classic Honda Community Chat
    Last Post: 01-11-2010, 06:09 PM
  5. Black Lxi Sedan or White Sedan
    By MyGarbageLXi in forum Classic Honda Pics & Videos
    Last Post: 10-01-2002, 07:04 PM
