so hears the deal.
i have an 89 lxi and the number 2 piston connecting rod bearing is shot. The crankshaft is worn from it and it needs to come out to be machined or replaced. so my question is: what is the easiest way to remove a crankshaft from the car. I would assume just removing the tranny and then the crank from under the car, but there may be an easier way.
any help would be appreciated.
