Results 1 to 10 of 10
Thread: Oil Leak.....
    DX User TsubohachiLX-i's Avatar
    May 2009
    1987 Honda Accord LX-i Sedan
    Dallas, TX
    Oil Leak.....
    Hello 3GEEZ......!
    For a while now, my valve cover has been leaking oil (at least i'm POSITIVE that's where its coming from), and its beginning to annoy me. I replaced the valve cover gasket once and ITS STILL LEAKING, but luckily it does not interfere with the oil level because I believe the leak is very small.
    A HOMELESS MAN told me that my Cylinder Head needs to be Re-torqued....
    What's your opinion.......?
    *Need New Valve Cover?
    *Needs Another Gasket?
    *Blown Seal?
    Oct 2008
    1989 Honda Accord LX-i coupe
    Re: Oil Leak.....
    My valve cover used to leak the same way yours does, but a new valve cover gasket was all that I needed. You may have gotten the one-in-a-million defective replacement gasket, but that's not very probable.
    Does the oil leak only in certain spots, or does the valve cover ooze oil on all sides?
    Re: Oil Leak.....
    Is it coming from above the exhaust manifold or below? Which side is it leaking on?
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    Re: Oil Leak.....
    distributor seal ftl!
    that is if it's coming from that side.
    clean it all off real good and shiney. It'll be easier to see where it comes from then
    May 2009
    Dallas, TX
    Re: Oil Leak.....
    The oil leak is coming from ALL AROUND the valve cover, the only difference is that the leaks vary in quantity.....
    At the rear (above Intake Manifold): leak is veeerrry small, but noticeable.
    In the front (above Exhaust Manifold): the leak is veeerrry noticeable, as there are SMEARS near the Power Steering Pump. Also, there are OIL STAINS leading into the Spark Plug Ports, as well as oil that leaks at the LEFT CORNER (near the Distributor).
    SE-i Sedan 5 spd
    Re: Oil Leak.....
    Replace the valve cover gasket, and use a Honda OEM gasket. Make sure all the surfaces are clean before fitting the new gasket in place. Should take care of it, leaving only the:
    1. distributor
    2. oil filter housing
    3. oil filter o-ring
    4. cam cover gasket
    5. the other gasket you change w/ the timing belt
    6. oil pan
    7 head gasket (I think mine is leaking on the front right corner by the distributor, where I imagine there is a oil return drain from the valve train.
    8. the sunroof (just kidding)
    I used to bitch about oil leaks in the old Brit motorcycles. Now I can bitch about my Accord.
    Re: Oil Leak.....
    yeah mayne def check the sun roof drain.. if that gets cloged you will blow the welds right off the intake manifold
    Dec 2006
    1989 Accord LX & SEI
    Springfield, VA
    Re: Oil Leak.....
    maybe a warped valve cover!!! if you wait to long to change a leaking valve cover gasket it will happen!!!
    3geez is F**kin Awesome!!!
    May 2009
    Dallas, TX
    Re: Oil Leak.....
    Now that I got some leads, I'll try to fix the problem......
    thanks.....
    Re: Oil Leak.....
    It's possible you got a gasket that's been sitting on a shelf since 1987. If it felt really hard when you put it in, then try again with a fresh gasket. Remember also that the torque spec on those valve cover bolts is 7 ft-lbs. That's only slightly tighter than finger tight. I'm not sure how long ago you replaced it, but if the old gasket was leaking real bad, then you could be seeing residual oil that leaked from the old gasket. It's also possible that the valve cover got dropped or stressed in a bad way at some point and is warped. If you didn't, you should also replace the buttons. If those are had, you'll have a hard time getting a good seal.
  1. Oil leak Found.. now an even worse oil leak....
    By Christofur in forum 2geez Tech & Performance
    Last Post: 03-11-2011, 08:46 PM
  2. oil leak
    By strange in forum 3geez Accords
    Last Post: 02-06-2009, 11:38 AM
  3. oil leak (help)
    By Juggalo88Accord in forum 3geez Accords
    Last Post: 10-21-2008, 06:18 PM
  4. Oil Leak
    By DBMaster in forum 3geez Accords
    Last Post: 09-23-2008, 02:58 PM
  5. oil leak somewhere
    By AccordNut in forum 3geez Accords
    Last Post: 06-20-2005, 06:57 AM
