Results 1 to 12 of 12
Thread: Car not wanting to turn at low speeds
    May 2009
    Pelham, Alabama
    Well..nothing out of the ordinary happened to it that I think would have screwed up something really bad...but it's possible. When I drop below around 15 mph, the car is HARD to steer...like the wheels don't want to turn at all...any solutions?
    car is a 1989 Accord LX-i by the way...thanks for the input
    Re: Car not wanting to turn at low speeds
    power steering might have went out
    check fluid
    and make sure your pump is working lol
    May 2009
    Pelham, Alabama
    Alright will do that tomorrow, it's 1:30 in the morning here...if it's not that what are other possible solutions?
    how's the p/s belt look
    the 3 g is hella easy to steer even without ps tho.... sounds like the rack might be fubard
    SEi User codyJDM's Avatar
    Apr 2008
    '88 civic wagon
    SoCal
    Not exactly true, I had my p/s off my old hatch for a few days when I was replacing the pump and driving it was a huge pain in the ass. Maybe its cause Im so scrawny? haha.
    Joay's Avatar
    Sep 2008
    Misty Beige 1988 LXi Coupe
    Good way to build upper body mass though.
    May 2009
    Pelham, Alabama
    Ok...so I got some power steering fluid and waited for the engine to cool down to put it in. I put it in, fill it up between the lines..and take it for a 10 mile spin around town to see how it works. Well, I immediately notice that it made a HUGE difference, and that was obviously the problem...so I get back home, and pop the hood to make sure there are no leaks...well the fluid level has worked it's way back down below the line a pretty good bit. Are these tell-tale signs of a leak, or was it reeeally low and some was kept in the system?
    My guess is there is a leak it just hasn't showed it self yet. You want to use Honda powersteering fluid or equivilent made for Honda systems.
    May 2009
    Pelham, Alabama
    Oh yeah I got the Honda type...
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    put in more fluid, get in the car, turn the wheel back and forth about 20x, recheck the fluid
    only fill to the full line or it'll come out the top when your turning the wheel around
    You getting any drip spots? bottom of the p/s pump wet?
    May 2009
    Pelham, Alabama
    Nope...don't see anything leaking like that
  1. trany slamming into gear when at low speeds
    By sparkmaster123 in forum 3geez Accords
    Last Post: 11-24-2009, 12:30 AM
  2. 85 accord , Cutting out at freeway speeds
    By Covelo in forum 2geez Accords
    Last Post: 04-07-2006, 01:20 PM
  3. Car Wobbles at high speeds!
    By AccordAddict in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-14-2004, 06:03 PM
  4. Rim size & RPM's at highway speeds
    By Greg in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-20-2003, 07:04 AM
  5. top speeds?
    By safeel in forum Performance
    Last Post: 02-06-2003, 09:21 AM
