Page 20 of 34 FirstFirst ... 1016171819202122232430 ... LastLast
Results 476 to 500 of 849
Thread: Tdurr's Turbo Thread!
  1. #476
    89T's Avatar
    Apr 2004
    Re: Tdurr's Turbo Thread!
    that's the best way.
  2. #477
    besides a dyno tune! haha but i dont has money for that.
  3. #478
    Nov 2002
    Ridin Dirty in New York
    If you have the time and equipment (eprom burner, wideband 02 and a laptop) you can street tune and still do pretty good, esp with low boost
  4. #479
    thats how my tuner does it
    Nov 2002
    if you get a rom emulator such as an ostrich, you can tune the car while the engine is running, and if you datalog too, you can see exactly where and what you need to change right on your computer screen. Thats the ultimate.
  6. #481
    true.
    shhhh no body asked you :P
    Yea, i want to get a datalogger and be able to plug a laptop in so i can tune on the fly. My buddy had one in his eclipse and shit was gangster. His launch control built like 26lbs of boost.... thats just his launch speed lol...
  7. #482
    well i did some work on the car today, redid my catch can setup and found a bad leak but its fixed now!
    But while i was under there i found out i was missing the 2 bolts on my tranny mount that bolt into the tranny.... wtf??
    then i also seafoamed the engine so its all running pretty.
  8. #483
    89T's Avatar
    Apr 2004
    Now if YOU WOULD take to the track it would be great.LOL!
    Do you hear that ?? Tim take me to the track...tim..please...take me to the track.
    get a time we can brag about.. whoa! I must be hearing stuff...
  9. #484
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    lol
    tim you gonna take it to the ttack in raleigh right?
  10. #485
    lulz. i would love to but i still gotta work some small things out and get a clutch.
    lol
    nah, i need a clutch and i know i wont have one by then... and as of right now i dont have the $$ to get there im goonna try and see if i can work at the goodyear i use to work at next week for some quick $$ and yea... finding a job right now ftl.
    Also, my last edit didnt work of the last post but I also found that one of my dizzy threads stripped out from the head so i gotta get that helicoled along with 3 exhaust studs.. so now i got a nice lil oil leak on the front of my block/tranny...
  11. #486
    DX User trage's Avatar
    May 2010
    1988 Honda Accord DX Hatch
    hey i plan on turbo ing my a20a1 accord hatch (manuel)
    im converting it to pgm-fi from a 87 prelude (auto trans)
    i am going to run 8-10 psi on a t3/ t4 turbo
    i am going to use a 4-2-1 headers (custom attachment to the manifold) if wanted i can show a pre drawn pic of it
    450cc jdm injectors, safc apexi controller, 255 walbro fuel pump.
    the kit im getting comes with gauges, intercooler, piping, fuel press reg, wastegate, bov, voltage regulator, fan, oil cooler, oil catch tank, and turbo.
    getting a spec stage 3 clutch
    my question is : am i missing any thing for my build???
    and what kind of wiring problems am i going to run into converting to pgm-fi from that car??
  12. #487
    LX User gtmst3's Avatar
    Jul 2008
    1986 honda accord LX
    Waterbury
    i have a question: now after i removed my stock air box on my lx-i i said to my self wow there is alot of room between the back of the engine and the fire wall. so why hasent anyone put a turbo back there? it seems like it would work, with well, less work.
  13. #488
    sounds like a lot more work than the traditional off-the-manifold way
  14. #489
    guaynabo89's Avatar
    FL
    Quote Originally Posted by gtmst3 View Post
    doable
    small turbo, bracket to hoold it up and some heat shielding for the wiring harness etc, and it should workk.
    Tim should try this.
  15. #490
    89T's Avatar
    Apr 2004
    I think it would work, with the exception of there not being enough room for intercooler pipes.
    un-motivated!
    3GR
  16. #491
    Quote Originally Posted by trage View Post
    oil lines(feed/return) other then that ur list looks good.
    sounds like a pain. u have alot of wires and hardlines back there that i wouldnt wanna put that much extra heat too and along with the weird manifold and ic pipes.
    doable
    shhhh
    it would work but just be weird...
    and hopefully next week after i get paid ill have tint.
  17. #492
    May 2010
    as far as ignition timing goes am i going to need a cam, cam gears , msd??? or can the stock system be used? im sure it cant but correct me if im wrong
    and it does have the feed and return line with all the pieces to hool it up , sorry forgot to add that.
  18. #493
    guaynabo89's Avatar
    FL
    there is if you use an air to water cooler back there. :P Mr. Intercoooler.
    be very short piping actually. Lol
  19. #494
    u can use the stock ignition. as long as u have a btm.
    toche sir.
  20. #495
    Jul 2008
    Waterbury
    it would be like it is i beleve the german cars like vw
  21. #496
    89T's Avatar
    Apr 2004
    toche sir.
    toche indeed!
    un-motivated!
    3GR
  22. #497
    Nov 2002
    dont forget, the stock downpipe will be restrictive for sure, as the stock exhaust manifold probably will too. I think building a manifold is really the way to go. Dont forget, you have the axles in the way too, so getting piping in or out of that area under the intake mani will be a bitch...
  23. #498
    May 2010
    ok i found some cheaper injectors
    they are venom 440cc and i was wondering if they will fit into the a20's intake
  24. #499
    May 2010
  25. #500
    Nov 2002
    they will fit but i think they are saturated type injectors, you want peak hold type. Id just use some used DSM 450cc bluetops
  1. Turbo Vic's 3g OBD-0 B18A Swap Thread
    By SQ is the SQUAD in forum General Engine Swaps
    Last Post: 11-25-2012, 04:35 PM
  2. Every turbo thread i bumped tonight.
    By 89T in forum 3geez News & Site Feedback
    Last Post: 11-11-2012, 10:27 PM
  3. Tdurr's Offical Thread
    Last Post: 04-16-2011, 12:59 AM
  4. Victors turbo non-progress thread
    By SQ is the SQUAD in forum Forced Induction
    Last Post: 02-17-2007, 06:35 PM
  5. Announcement Support Thread - Turbo, 1st & 2nd Gen Forums
    By 87accordlxi in forum 3geez News & Site Feedback
    Last Post: 02-21-2006, 06:35 PM
