^His car hates him and he fails at driving.
~~NGK~~Silvania~~MSD~~Pioneer~~MSW~~Bosch~~DC Sports~~115WHP 116WTQ
man looks like its new tranny time
sweet. vids time LOL..
soo no vids for a while. at least if i do them its gonna be a one gear pull. after driving it i found out it grinds every gear. but it works. I gotta double clutch or let the rpm drop to 1500ish before it plops in gear :/
hopefully i can get a job then get a brand new tranny maybe a bit of lsd!
try adjusting your clutch
sounds like you need to adjust the cable fool. DO IT NOW LOL. listen to us beaners lol
try to tighten it so it fully disengages when you push the pedal
I had to tighten mine pretty good in order to get it to shift.
un-motivated!
3GR
a few more turns.
un-motivated!
3GR
you need to make sure you have some endplay on release arm, because if its too tight itll do this too.
mkay ill loosten it up some then.
but i made a few runs sunday comming back from import alliance.. was kinda sad on the results.. but lets say 7psi(cuz of a damn boost leak that i cant fix) is not fast enough. I wanna beat some built B hatches.. alerjalekdjfalkjf
also, 14xx miles on the clutch and ive gotten balls to go WOT now. im boosting all around town hahahaha
Hi 89T. Yes! A little bit turns.
thats it. wtf bro you slacking LOL jk.
random update:
My car is still running. Needs a oil change still, and I need a job still, hopefully i can get something figured out.
Also I helped Pete start his car the other day and get it started so here a a few teasers with the ksprots at a mild hight
yikes thats mid height? Must be able to drag your subframe on full low.
sexy. get er done fool
