your slacking my friend.
Nothing wrong with 15 .si. lol
Get tuned homey.
needs moar boost for all that fuel your dumping...
Tim tune it you'r self. You have a wideband. what else do you need. The afc is freakin easy to tune.
Gio is right turn the boost up or back off on the fuel.
un-motivated!
3GR
My car never threw a code on the afc. and ran a 14.2 at 5k elevation.
un-motivated!
3GR
lol well i just checked the plugs and they were backwards -_- the P.O. had em set like that and i've always assumed they were pugged the right way... code it gone, it deff idles diff now... sooo i might be re-"street tuning" my car this week now that its not in like cold start up mode or w/e u wanna call it.
limp mode...![]()
un-motivated!
3GR
yes, but only for 1 sensor.
you may be able to use a 1 way diode on each wire and run only 1 o2... If that makes sence...
Last edited by 89T; 03-14-2011 at 05:51 PM. Reason: heaven on earth i will edit. Mr. Hun-duh
un-motivated!
3GR
0-5v. the diode will prevent feed back from the opposite wire.
un-motivated!
3GR
mkay well radio shack is closed now so ill hit it up tomorrow and pick some up and let u know how it goes.
ive also noticed that my a/f gauge(narrowband) isnt reading anymore... i gotta check the wires on that.. if its good then i might have fouled out my o2 sensor haha
Fail my brother fail... LOL. See what you get and let me know.
un-motivated!
3GR
http://forum.clubna-t.com/showthread.php?p=70593
so reading some of that im gonna have to switch a pin on the back of my wideband to go to 0-1v output for th narrowband right?
and i wont have to splice in i diode from what they are saying. just splice it into the ecu because the ECU just reads the voltage it doesnt send anything to the o2 sensor.
So in theory, i could just (at the ecu) splice my wire from the wideband to the two o2 sensor inputs and be done as long as i hit the switch on the back of the sensor?
yup, but i would use the diodes to prevent any feed back.
un-motivated!
3GR
I'm upset with you time. You fail once again lmfao . I have a CEL but thats cause of my egr. But obd1 well take care of that. I have a CEL on my civic steady one once I turn the key o. Its on lol. Runs good an beast but idk what these fools did.
lol okay so i prob wont do that.. why? cuz im lazy.. haha
who is time?
lol but idk, ive just thought the ecu was bad and was looking at a pic and was like wait.. my plugs are flipped around.. wtf man!! I replaced the plug and even got a new TW sensor last year and it didnt fix it so i gave up haha.
but i just went to wendys and now the VSS is bad according to the ecu and i cant hit the gas more then like 15% or it just sputters![]()
okay so i reset my ecu, and it idles fine, and runs okay up to 40mph then the vss kicks in bad(thats where my speedo starts bouncing) and then after that it keeps trying to richin the car up at speed and idle(via wideband) and just acts crazy. idk im sorta stressing hard seeing how i have class at 10am and i was supposed to ride down to my moms and help her do something tomorrow... ugh fml.. i fix one thing and something else thats really dumb happens..
