Results 1 to 13 of 13
Thread: Headlight switch help =(
    LX User LxAcc510's Avatar
    May 2008
    1989 Honda Accord LX
    Where they say Hella, CA
    Unhappy Headlight switch help =(
    Hey guys. My light switch went out. I got off work late last night started up turned (tried) on the headlight and that bitch turned and i felt something gave and now I have no light switch. Anyone know how to fix this?
    Basically when I tried to switch the headlights on I had to force it to the parking lights position and when i did that it gave way and now i can roll the switch back and forth like there's nothing in there.
    Is there a way to switch out or yank out this switch? I have a feeling I'm gonna need a new one.
    Also my dad told me to figure out where the headlight relay is? Yea i know that's a noob question. But hey I'm a noob.
    HELP ME PLEASE! I have to drive at night! Last night driving home i had to flip up the lights hold on highbeems and drive around with my hazards on! I was lucky i didn't get pulled over!
    '89 LX 295,000 3/1/09 =D
    Re: Headlight switch help =(
    you need to go grab another one from Pick and pull, same thing happened to the 89
    May 2008
    Thought so. Does it come off at the switch or do i pull away the wheel and stuff then the entire assembly of the switch bar thing comes off?
    steering wheel comes off and so does the plastic steering colum housing.
    get one this week and come up to the house if you need help anytime this week if you want help
    do i hear junkyard run?
    carotman's Avatar
    Montreal South Shore
    I'm sure you can just clean/repair it.
    I need these parts!
    SE-i Sedan 5 spd
    There are no headlight relays on our cars, that's why you can't go over-wattage on the headlight bulbs, you'll kill the switch (been there).
    bridgewater.NS Canada
    I thought there was one in back of fuse panel under the dash,i think its yellow.
    SE-i Sedan 5 spd
    Nope
    If he can spin the stalk round and round that means the little plastic pin molded into the rod at the end that moves the slider in the switch is broken off. You can glue it back on, but its easier to get a new switch, rebuild it and forget about it.
    1986 Honda Accord EX (1.6) carb Manual
    Karachi Pakistan
    the relay in the fuse box is the high - low beam interchange - usually on fixed headlight cars
    Awaiting Activation ArokASE88LXi's Avatar
    Jun 2008
    88 Honda Accord Lxi A20A3
    Castle Rock, CO
    i've had problems with switches in both of mine i bought one frome ebay and it did the same thing. this might be different than yours but on mine now the outer switch rotates and the inner part rotates too so i have to hold both and line it up where i want it. but i have a feeling your problem is different right?
    NEVER argue with an idiot! They'll drag you down to the're level and beat you with experience!
    Well my 87 lx has the yellow headlight relay in the back of the fuse panel under the dash.Unless it's a canadian thing,don't know.
  1. headlight switch
    By HONROD in forum 3geez Accords
    Last Post: 08-26-2011, 04:49 PM
  2. Headlight switch
    By 87AccordLXsdn in forum 3geez Accords
    Last Post: 01-11-2010, 02:02 PM
  3. headlight switch
    By skylinegts in forum 3geez Accords
    Last Post: 04-01-2009, 01:40 PM
  4. Headlight Switch
    By kyleeatsrocks in forum 3geez Accords
    Last Post: 11-07-2004, 07:03 AM
  5. Help Anyone know how to chance a headlight switch ?
    By 3genAccordEXI in forum 3geez Accords
    Last Post: 03-08-2003, 12:01 AM
