Results 1 to 7 of 7
Thread: 120v plug
    LX User canadian357's Avatar
    Feb 2008
    '88 Accord LX, '87(?) LX-i
    Edmonton, Alberta, Canada
    120v plug
    I know about the LM7805 to wire usb ports into the car, but is there an equivalent for 12 volt to 120 volt? Or do I have to build one?
    Re: 120v plug
    You'll need a power inverter. You can mount it in your trunk like an amplifier, run it straight to the battery for the best power. A decent one that will run just about anything except a microwave will cost about $30-40. Then plug an extension cord into one end and strip the other end off and wire on your own receptacle and cut a hole somewhere like in your center console. That's what I did anyways.
    Vanilla Sky's Avatar
    1999 Penalty Box
    Re: 120v plug
    I'm putting one under the passenger seat. I need to power 2 laptops and the occasional random other items. I figure that I want 800 watts of power is more than enough for my needs, but your needs are probably less.
    Re: 120v plug
    I was able to run a desktop PC, laptop, and CRT off of a 400 watt peak inverter. 800 watts should do nicely.
    Feb 2008
    Re: 120v plug
    Just hack off the lighter socket end and solder it to a 12v wire? Also, what's the easiest way to get the power to my dash 12v plug to shut off when I shut the car off? I hate having to unplug stuff so my car doesn't die overnight.
    Re: 120v plug
    Quote Originally Posted by SHENANIGANS View Post
    your best bet is to tap off the fuse panel...i used the radio fuse to power my radar detector
    Re: 120v plug
    No, wire it off your battery and put a relay in line with a switch on your dash. Then you can flip the switch on and off to turn off the 120v setup.
  1. how do you get the plug off the...
    By dirtracer in forum Carburetor Tech
    Last Post: 06-04-2006, 08:30 PM
  2. To plug or not to plug. . .
    By Shadowkat in forum 3geez Accords
    Last Post: 01-09-2006, 11:51 AM
  3. FS: MSD Plug Wires 30.00
    By speed.freek in forum Trading Post
    Last Post: 09-14-2003, 08:00 AM
  4. What's this mystery plug for? <pic>
    By Jareds 89 LX-i in forum 3geez Accords
    Last Post: 03-21-2003, 11:12 AM
  5. What are these and can i plug them
    By Mantis88LX in forum Carburetor Tech
    Last Post: 02-01-2003, 03:40 PM
