Results 1 to 5 of 5
Thread: T-stat failed
    T-stat failed
    Well just missed blowing my car up. By somewhat chance I had hooked up my Innovate wideband doing some full throttle pulls etc and damn if my car didn't peg the temp guage. By luck my wideband was reading way rich and I just did a guage check and it was pegged. I think I saved it with a quick cool down, running the heat and both fans and starting it every 2 mins to pull the temp down.
    As you can see from the pic it split the place where the rod is crimped on. It must have jammed at high RPM's. Its gonna be a bitch to fix. Those bolts I had put in like 10 years ago last I did a T stat. The old ones I had to drill out and retap it the next size standard size.
    Im gonna need a new housing I would guess any one have any ideas.
    Re: T-stat failed
    Just try and get those bolts out. If not then just get a new housing, thats what I had to do.
    May 2008
    los angeles
    Re: T-stat failed
    wow.. never seen a t-stat do that before.. post pics of it when you get it out man
    -Tom
    1988 4 Door Lx-i 5-speed
    364,XXX and counting :]
    Re: T-stat failed
    Sorry to see that Old Blue. You're not alone in having that housing crap out. I had to replace mine. It's easy enough. Just takes some time to feed your 12mm box end wrench back there. Good luck getting it fixed.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: T-stat failed
    I don't run a t-stat in the summer. In fact, I had to drill out a bolt that broke off & just put a bolt all the way through with a nut on the other side. I doubt I'll ever put a t-stat back in with the trouble it's worth. It's not like my car is fuel injected.....
  1. I need: A water pump stat!
    By tomatofiasco in forum 1geez Accords
    Last Post: 07-30-2009, 01:33 PM
  2. heater core diagram STAT
    Last Post: 02-11-2009, 04:50 PM
  3. 87 a20a3 bypassing thermoswitch on t-stat snout
    By mykwikcoupe in forum EFI Tech
    Last Post: 11-19-2008, 07:49 AM
  4. MotoRad T-Stat
    By 7a7Accord in forum 3geez Accords
    Last Post: 04-23-2005, 08:05 AM
  5. Installing T-stat?
    By Dennis in forum 3geez Accords
    Last Post: 02-10-2004, 04:22 PM
