2ndGenGuy
And you didn't come to the meet and the dyno day!?
No your car should be making more horsepower. My Accord put down 67 with the stock 1.8 liter and a 32/36 with 275,000 miles and lots of burning oil. Even with shot rings, and low compression you will make more power than that. At 310,000 miles, with all bolt ons on the same motor and a Weber 38, I made 97whp with the 1.8 liter. So oil burning, low compression, worn motor, knocking rockers, I was still able to pull more HP than stock. Your motor will have to be REALLY REALLY shot to lose that much HP.
Did you have an air fuel map done while you were on the dyno? That would have told you right away if your ratios were off and you needed a tune. Also did you check your timing? Timing being retarded will kill horsepower. What kind of dyno were you on? Was it SAE corrected?
A 32/36 will not give you much power over stock. It's almost the same size as the stock carb. If you're looking for a bit more juice, you'll need a 38 anyways. Or a 40, or 45 or 50, but those get spensive.
