Results 1 to 24 of 24
Thread: 87' carburetor rebuild...
    Jun 2009
    87' Accord LX
    Mo-town
    hey, ok, so my 87' accord has been nothing but problems since i have had it, so the original carburetor float valve went out and it hydro-locked my engine, so i ordered another carb from the wrecking yard and when the mechanic put it on it was leaking BAD BAD BAD, so now i ordered a carb rebuild kit and am going to rebuild the original carb
    but i hear it is a PAIN and 9 times out of 10 they dont work when your done, but i really dont have any other choice, i looked around the internet and some of the forums on here and i cant really find a good article on doing it, can anybody help me out on this??? i can supply pics of the carb if needed for somebody to make a diagram or something, well thanks for any help!!!!
    Ichiban's Avatar
    North of You.
    Re: 87' carburetor rebuild...
    Rebuild kit should come with an exploded diagram of the carb, and installation instructions, should it not?
    ICHIBAN!
    "Now, even more better!"
    Jun 2009
    87' Accord LX
    Mo-town
    Quote Originally Posted by guyhatesmycar View Post
    i ordered it from autozone and the guy said something about instructions but im not sure about if its a blow-up diagram or anything, so im really not sure, and i guess theres no place in town that rebuilds foreign carbs either, so i really need this to work, lol
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Wink Re: 87' carburetor rebuild...
    These carbs are a bitch to rebuild. I used to rebuild them & sell them as a hobby. That got old & I was never was happy with my idle. Personally, I've never been happier since I switch over to a WEBER!!! I keep telling people these carbs are not worth messing with when they start messing up. Slowly but surely they wake up after hours of wasted time & money.........
    LX User greentee76's Avatar
    Feb 2008
    1988 Honda Accord LX 5sp
    Kalamazoo,MI
    Weber... FTW
    88 LX 5spd l 32/36 weber l KYB GR-2's l Refreshed A20A3 engine l
    Jun 2009
    87' Accord LX
    Mo-town
    Quote Originally Posted by 88Accord-DX View Post
    yeah im sure your rite about it being a bitch, but i really dont have a choice money wise, but what is a weber exactly??? i checked out some website and it seemed to be like performance parts for the carb or some kind of conversion kit to turn your carb to FI, but im not sure and it seems damn expensive, lol
    weber is a replacement performance carb
    Jun 2009
    87' Accord LX
    Mo-town
    so whats all involved in getting one of these installed and running other than buying the physical part?? will the airbox still fit over it and does the base of the carb match up on the car??? and whats the exact one i would need for my car??? sorry bout the questions but i have never had to deal with carbs, my last car was FI, although it was still a POS, lol
    they make the adapter plate for it.. and it comes with a new air filter/air box
    the whole carb looks like this once installed
    and you would need a weber .38 or a 32/36
    i believe the whole setup with adapter plate runs about $300 something
    heres a 32/36 on ebay right now with the adapter plate and everything
    http://cgi.ebay.com/ebaymotors/Honda...lenotsupported
    exactly, if the internet were around in 87 you would have read the same thing back then. It was par for the course to replace Asian carbs with holley and weber aftermarket replacements. Under par actually, beat the course!
    Quote Originally Posted by zack_attack2010 View Post
    importcarbs.com check him out best price i've seen yet
    it was just under 300 for an 86-89 carb. he hand rebuilds each one personally,been in buisness forever.
    but if its just under $300 wouldn't it make more since to pay $350 to get the weber and actually have some sort of performance
    i'm talking about if you have to have the original
    That's mistake #1. Rebuilding the carb is going to be hard enough, you don't need a second-rate kit to make things worse. I'd get a kit from Napa if you can.
    I haven't rebuilt any of the 3g carbs, but I've built 1g and 2g Keihin carbs. The trick is to take apart as little as possible. Keep careful track of what you do remove and how you remove it. Clean everything carefully and ensure you reassemble correctly. Most importantly, sit down with the manual (available here: https://www.3geez.com/forum/showthread.php?t=25137) review the parts about carb disassembly and reassembly and make sure you understand everything before you start. Pulling the carb, taking everything apart and then trying to remember how your bucket-full of parts fits together is a recipe for massive failure. Work on a large table covered with something you can write on. As you remove a part, set it on the table, put a box around it and give it a number. The first part will be 1, obviously. Place the next part next to it and mark it 2, etc. Just be careful and methodical and you'll be good. The most difficult part will be adjusting the float levels. Be very careful to do this properly. Some carbs have windows with marks where the correct level is and that makes it real easy. Just fire up the car and tweak until it's right.
    Good luck!
    True.. like cali owners damn smog checks!
    Good luck!
    I hate rebuilding the things, used to have all the special little tools and all, like the ones for setting the float level correctly in the aux float bowl ,dk what happend to all that stuff, but even after doing surgery on them in a clean room on white paper,they still sometimes never work right again.
    tell you the same thing i tell everyone else, importcarbs.com guy built some carbs for me years ago, great job, i always recommend people who do good work. they are a pain to fix,and stuff like the top hat you can't fix yourself ,need special tools. he went down in price 86-89 are now 229 plus tax
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    I wouldn't sell him on getting his oem carb rebuilt by himself or any guy at carbsareus, or what ever... These carbs are junk & the engineering wasn't good.
    I think he is required to have an oem carb isn't he? not trying to sell him, they just have good prices and i've dealt with them before, trying to pass the info along. if he can put on a webber then go for it.
    Jun 2009
    See a recommendation for a importcarbs.com. Is this still a good source for rebuilt oem carb for '88 Accord DX?
    Nov 2013
    I see it eliminate all the hoses and wiring from the engine bay....
    Oct 2017
    How hard was it to switch to aweber?
  1. Carburetor Rebuild , Top Gasket Printout / Other Gasket Info
    By Knowledge Base Admin in forum Carburetor Tech
    Last Post: 06-24-2019, 09:02 AM
  2. Carburetor adjustment
    By Rippen Griffin in forum 1geez Tech & Performance
    Last Post: 07-25-2010, 07:47 PM
  3. carburetor
    By badbobb in forum 2geez Accords
    Last Post: 04-01-2009, 03:45 PM
  4. Carburetor idle
    By russiankid in forum 3geez Accords
    Last Post: 04-14-2008, 07:50 PM
  5. to rebuild them or not to rebuild them, that is the question
    By ZackieDarko in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-20-2007, 06:46 PM
