Alright, I have an 89 honda accord lxi with pretty low miles (108K) but the suspension isn't holding up and I need some help to keep it on the road for another year or so. I took it to a Honda dealer to replace a seatbelt and they of course were looking for other stuff to fix. They said the front lower right ball joint needed to be replaced and upper and lower arms back left arms need to be replaced. They said over $2000 for all that. In my experience you can't trust dealerships so I just said "no" and didn't think much of it. However, there's definitely some problems and they're getting worse...
When I make turns at a certain angle you can hear the right front tire wobble. It's a scary noise as if the the wheels is just going to fall off. It has gotten worse where I hear it wobble when I go over bumps. I'm assuming that's the ball joint coming loose. I've looked around and it looks like if I let it go sooner or later the ball joint with come loose and the tire will go sideways and I'll pay more in the long run (especially if it causes an accident).
Also the back left suspension constantly makes this kind of popping noise as if you were popping a dent of out a piece of sheet metal as I go over little bumps in the road. Doesn't seem like a major problem, just gets annoying.
So... is there an easy fix to this? Maybe a little grease here and there or something or do I need to start shopping for prices to replace the ball joint and back right suspension? I'm assuming this isn't an easy DIY replacement so if I need to start shopping what kind of price range should I be looking at to get the job done?
What do you guys think?
