Results 1 to 10 of 10
Thread: Water pump Connecting pipe
    Awaiting Activation ArokASE88LXi's Avatar
    Jun 2008
    88 Honda Accord Lxi A20A3
    Castle Rock, CO
    Anyone ever replace this?? I'm putting together an order for majestic for some other gaskets and stuff and it's only $27 brand spankin honda new. i'd like to get it just to have around, but also i have the intake off now and can get to it incredibly easy. has anyone tried to replace it is it pressed in pretty hard. I'd love to hear from anyone with any experience replacing this!!
    NEVER argue with an idiot! They'll drag you down to the're level and beat you with experience!
    LX User greentee76's Avatar
    Feb 2008
    1988 Honda Accord LX 5sp
    Kalamazoo,MI
    Re: Water pump Connecting pipe
    Once you remove all the bolts securing it to the block it just pops out. The only thing that holds it in is an oring seal.
    Jun 2008
    Castle Rock, CO
    wow i guess i didnt see the bracket that bolted it to the block. i just took it off! great thanks a lot i'll order with confidence now!
    Jun 2008
    Castle Rock, CO
    how about the pipe comin out of the head the one that screws in. Ever replace that before? i'm not sure if i wanna try unscrewing it might be stuck in there leaving me screwed if it comes apart.
    carotman's Avatar
    Montreal South Shore
    unless this one is rotten, just leave it there.
    Feb 2008
    Kalamazoo,MI
    Yeah, I have swapped them from head to head. A regular pipe wrench will extract it. But, remember it is a steel pipe in an aluminum casting. As Carotman said I wouldn't touch it if it wasn't absolutley necessary.
    Quote Originally Posted by greentee76 View Post
    I took mine out,but because I tig welded a steel threaded fitting to the end of it. it's an oddball super fine thread, I had no problems getting it out, once it's out you need to clean the threads, then coat them with something like indian head gasket shellack, for a permanent thread seal, it is in there really tight.
    Jun 2008
    Castle Rock, CO
    Thumbs up Re: Water pump Connecting pipe
    Well i was putting in an order to majestic and it was only $6 so i thought what the hell. I see what your saying about the steel into aluminum issue I guess what i'll do is leave it for now and try taking it out of the spare 88lxi head i have and replacing that one if it works it gives me a good excuse for beefing up that head i guess.
    Quote Originally Posted by ArokASE88LXi View Post
    it will come out with a pipe wrench actually pretty heavy walled tubing.
    Jun 2008
    Castle Rock, CO
    Ya that's what I figured on using it's not left hand threaded or something retarded like that right? Well my order hasn't even shipped yet i believe, maybe i can call them and add another coulple o-rings before they do. Last time i ordered it took a week before anything shipped but when i looked on my reciept every single item was special ordered ha ha. but i got my breather filter and new green vacuum hose today so that makes me happy
  1. o ring on water pump pipe
    By lostforawhile in forum Carburetor Tech
    Last Post: 11-25-2009, 08:25 AM
  2. Replies: 16
    Last Post: 11-05-2004, 09:21 AM
  3. Water Pump inlet Pipe
    By Vinny in forum 3geez Accords
    Last Post: 02-20-2004, 06:05 AM
  4. WTB Connecting pipe
    By Ohiodx in forum Trading Post
    Last Post: 08-30-2003, 03:33 PM
  5. Re-Connecting Water Temp Gauge?
    By Site in forum 3geez Accords
    Last Post: 01-30-2003, 01:57 AM
