Results 1 to 6 of 6
Thread: b20a tune up specs
    Washington
    b20a tune up specs
    Im looking for an actual guide for the tuneup with spark plug gap, timing specs, firing order and all that jjazz. Im basically going off what Ive read online from others and guessing firing order from the pics. My b20a is having a hard time starting and Id like to narrow thai down. The dizzy is loose since its from a donor car. My plug gap is .44mm firing order is 1-4-3-2 and a valve spec would be great as well.
    Haunted ca3 says there is a tune up guide on wki but I cannot find it anyplace. Thanks for the help. Mike
    Nafs Asdf's Avatar
    Feb 2008
    Finland
    Re: b20a tune up specs
    Quote Originally Posted by mykwikcoupe View Post
    You should find all the specs in the shop manuals, '87 supplement I think had the main stuff on the B20. Also I'm pretty sure the firing order is 1-3-4-2, so if you got it in the order you posted it's not strange if you're having trouble starting it.
    Washington
    ok Ill try that Ive been going off the 88-89 on paulsdesign page.
    Washington
    .39-.43 is the plug gap and mine are set to the b20a5 .44 so my timing is definatly off. i do not have the dizzy static timing set yet. My plug wires have been double checked and I pulled a dislexic and transposed the 4-3. Ill go through and check everything else. Thanks for the help.
    care to share those specs???
    what manual has jdm b20a stuff??
    I also would like to see a schematic for the TCM for autos
    Nafs Asdf's Avatar
    Feb 2008
    Finland
    Just use the edm manual, most stuff is the same.
  1. b20a specs
    By b20a86lude in forum JDM B18A / B20A Swap Tech
    Last Post: 04-11-2009, 03:17 PM
  2. 300 000 + Kms Tune Up
    By JFreddy in forum EFI Tech
    Last Post: 12-15-2006, 05:26 AM
  3. b20a specs?
    By stevenr816 in forum 2geez Accords
    Last Post: 06-29-2006, 03:43 PM
  4. B20a gold top specs
    By Versanick in forum 3geez Accords
    Last Post: 09-08-2003, 01:47 PM
  5. ACCORD SPECS: tell us your specs?
    By sanjay in forum Classic Honda Community Chat
    Last Post: 08-13-2002, 11:18 PM
