Results 1 to 12 of 12
Thread: DISC and DRUM similarities
    SEi User ZackieDarko's Avatar
    So I decided to be productive last night and started pulling my drums off my hatch to see what the rear discs would look like on there.
    In the course of this I noticed that the DRUM setup uses the same hub as the DISC setup.
    Also the diamater of the OEM sized rear disc is the exact same as the diamater of the backside (that houses the hardware) of the drum assembly.
    WEIRD
    Re: DISC and DRUM similarities
    Yeah, but no caliper mounts on the drum knuckles.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Yes, if someone was motivated enough a plate could be made to replace the drum backing plate and allow a disc caliper to bolt up... There wouldn't be enough interest to make it worth anyone's time though. Much easier to find a set of spindles with everything you need at a jy... Cheaper too, and that's what we're all about on here.
    CARDONE SUCKS.
    carotman's Avatar
    Montreal South Shore
    Yup, I'm using my drum spindles because the ones from the disc conversion were shot.
    I drilled/tap the holes for the disc screws tough.
    I had thought about looking into a setup that was more friendly parts wise on the rear calipers but I never done much research on it.
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    i have most of the parts for this conversion also, but im still hearing that the rear trailing arms are different for the drum and disk setup, i got an 87 lxi hatchback , so i don't know of i need to get a set of trailing arms b4 i try this.
    i was told this as well but from what i can see all the bolt holes align just fine (86 LX-i)
    Sep 2006
    Tucson, AZ
    I believe the only difference in the 86-87 is the bracket that attaches the spindle to trailing arm... You need to use an 88-89 bracket and use a bolt and nut to attach the brake line if not off an SE-i
    CARDONE SUCKS.
    SEi User turabaka's Avatar
    Aug 2007
    Boise, ID
    I just used the trailing arms off my 88 hatch. I have no idea if the 86-87 ones work though.
    I didn't have any problems with my trailing arms. I do however have an 89'.
    1989 Lx-i Hatchback
    Jackson, NJ
    yah i think i got the horseshoe looking bracket with the 4 bolts on the back of the knuckle im still curious how different the 86-87 brackets are compared to the 88-89's
    yup i remember comparing mine when i put on my disks...it was really close
  1. b20a b20a5 differences and similarities (photos and video)
    By Naxo-Zka in forum JDM B18A / B20A Swap Tech
    Last Post: 12-15-2011, 09:32 AM
  2. Drum Wet
    Last Post: 07-26-2007, 08:39 AM
  3. Rear Drum to disc conversion
    By P|eszczoH in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-08-2004, 07:30 AM
  4. Rear Drum to disc conversion
    By P|eszczoH in forum EFI Tech
    Last Post: 08-14-2004, 03:26 PM
  5. hang ups on the drum to disc
    By markmdz89hatch in forum 3geez Accords
    Last Post: 08-13-2002, 06:20 PM
