Results 1 to 14 of 14
Thread: higher redline
    Jan 2009
    1989 Honda Accord LX-I Coupe
    Houston, TX
    higher redline
    for those that have been keeping up with my posts know that i am going to do some engine work to my car. well now i am ordering parts and really want to bring up my redline preferbly to 8k but atleast to 7 so what should i upgrade and how should i go about this?
    DX User 89lxisedan's Avatar
    May 2009
    westford, massachusetts
    Re: higher redline
    get rid of the rev limiter
    LX User greentee76's Avatar
    Feb 2008
    1988 Honda Accord LX 5sp
    Kalamazoo,MI
    Re: higher redline
    My 2 cents...
    A20's really don't make that much power that high in the RPM's. What little that you can ring out of it in the upper RPM's are not worth the stress and possibility of failure that also occur up there.
    88 LX 5spd l 32/36 weber l KYB GR-2's l Refreshed A20A3 engine l
    Feb 2008
    Kalamazoo,MI
    Re: higher redline
    IF you are set on doing this you are going to need to go with better valve springs, probably a different cam. But really you are going to need a lot of P&P work done on the head to make it worth it.
    Jan 2009
    Houston, TX
    Re: higher redline
    wat about gettin ready for a turbo other than a turbo cam regrind and redoing the head will i require anything else?
    Re: higher redline
    P&P head for best flow beyond 6.8k The power really hits a wall with our ecu's. GO obd1, and apparently the power wants to climb after 6.5k lol.
    Cam is a must, 272 for mild street na or turbo. But for just turbo, a 267(i think)/272 is the way to go.
    Or just get a bisi cam lol.
    oh yea rods are the weak points on our motors, we can use the stock ones past 7k alot. So stronger rods is a must.
    LXi User Bass Man's Avatar
    Jun 2008
    Rogue River, So. oregon
    Re: higher redline
    I had a nice descussion about the same thing. Let me try to find it.
    Jun 2008
    Re: higher redline
    my old 3g used to go up to fuel cut alot which was like 7200rpm
    Re: higher redline
    if your asking on what to chance to do it.. then you probably shouldnt be doing it at all...... but in a short list heres things to conisder
    crank
    bearings
    rods
    tuneing (obd1?)
    fuel
    etc etc etc
    Re: higher redline
    OOOO BOI...k here i come...
    First off a stock a20 wont cut it.youll need atleast a rebuild a mild sort as in head valve springs. cam and such. if not youll valve float and BAM youll bend a valve thus hitting the piston and your done....so in order to see great performance youll need OBD1 (since i seen messys car) that thing hit 7g like nothing and sounded like i wanted more which it would of EASYLY. well.....EVEN with stock rebuild youll need a head work to get 8g....turbo you wont feel it but when it goes out....then youll feel a rod go thew the block...
    I got all stock bottom end. with alittle bore. p&p head. 3 angle valve job. stage 2 delta. and i have a 86 head so bigger valve springs. all comes to play...i would do some research look at other 3geers setups bro...
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Re: higher redline
    Let me add my two cents. To make decent power above the stock redline, you will need a Port and polish job. Valve springs have been said, and its absolutely true. On the bottom end, the crank needs to be balanced by now (wear has taken its toll, im sure) and the stock rods and rod bearings MUST be replaced. Much over 7k will grenade those. After that, i would just be damn sure that every seal and bearing has been replaced. You cant go runnin around with a stock motor revving over the stock redline, you WILL throw a rod or break shit. NOT smart.
    '89 SE-i Coupe
    Awaiting Garage
    Re: higher redline
    yeah you would have to rebuild the enigine to get it to rev that high...on a stock car its worthless
    Justanothermike's Avatar
    88 LX-i coupe 91 LX coupe
    CA, San Francisco
    Re: higher redline
    You can safely rev up to 7.5k with the addition of some ARP Rod bolts. Heck we took it up to 8K. Horse power would max out around 7K maybe a little bit higher with higher compression. This is with a very aggressive cam and headwork.
    https://www.3geez.com/forum/showthread.php?t=57136
  1. idling at redline
    By oscwrestler in forum Carburetor Tech
    Last Post: 09-10-2008, 09:59 AM
  2. 1st gear redline
    By juxbill in forum Classic Honda Community Chat
    Last Post: 09-16-2005, 08:30 PM
  3. redline
    By alboy in forum Classic Honda Community Chat
    Last Post: 05-20-2004, 09:06 PM
  4. Redline Difference?
    By 89AccordLX in forum 3geez Accords
    Last Post: 11-14-2002, 10:12 PM
  5. Redline MTL??
    By 88LXiHB in forum Performance
    Last Post: 05-03-2002, 08:25 AM
