What he means what is it used for..
Well it tricks your map to spit more fuel to w/e your set the S-AFC at. which for boosted apps Roach you would need to run more fuel so you would dail in a lower percent ratio on the afc thus tricking the map to spit more petro. has a hi and low setting so when your just at regular driving matters w/e you set on your low is what it well go to..on the other hand you got the high which is when you get WOT it shoots what you put. i have both hi/low the same...theres no need to get all fancy with doing all the other bs. Works great at first my car would shot out craps load of snoot and not run. its a cool little unit if you keep your obd0 setup...which i wouldnt..
Yet you can use the S-afc on your obd1 to fine tune inbetween the gaps that the chip burning couldnt get. works good either way as a piggy back or a kinda alike a standalone...
Makes sense? all it uses is your map for tuning.
