Results 1 to 9 of 9
Thread: Rear trailing arm bushing diameter
    Feb 2004
    89 accord lxi
    down by the bay
    Question Rear trailing arm bushing diameter
    Does anybody have a trailing arm bushing lying around? I need to know the outside diameter of one of these bushings.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: Rear trailing arm bushing diameter
    No other honda bushing matches up. I've tried, it's an oddball. But I can get measurements in a day or two if you would like.
    CARDONE SUCKS.
    Feb 2004
    89 accord lxi
    down by the bay
    I'm going to try and make a housing bored out for an M12 spherical bearing.
    If you can get measurements with a set of calipers that would be awesome.
    Oct 2000
    '88 Accord LX-i
    Connecticut
    are your current bushings ripped? I know this is a known problem with EFs,EGs,DAs,DCs and EKs.
    I have never seen any ripping on any of my trailing arms...so I am just curious
    '88 LX-i Coupe --- LS/Vtec
    VERY common on EF/EDs^ both are trashed on the 91.. along with every other bushing heh
    Feb 2004
    89 accord lxi
    down by the bay
    The bushings are fine I replaced them about 4 years ago. I want to get rid of the fore/aft deflection. Going to do the same thing with the radius rod bushings. Typing on phone suck.
    I would go solid in the rear either plastic or aluminium. I am having very good luck with the blue nylon plastic in alot of my bushings. The 4 small bushings at the end of the link I dont understand what there there for???
    The radius rod bushings the replacements are very hard good improvement over the old stocks. I got a write up on here.
    https://www.3geez.com/forum/showthrea...t+rod+bushings
    If you go solid up there I would replaced the front support totally with homemade or aftermarket and go heim joints both ends. I dont think a solid bushing up there would work without some kinda bind but you can try it and prove me worng.
    Feb 2004
    89 accord lxi
    down by the bay
    The trailing arm bushings I don't want solid because they have to be able to swivel a tiny bit. The way the rear suspension is set up, it toes in the more it moves away from static height. If I use a spherical bearing, I can get rid of the deflection but still allow the suspension to keep its natural range of motion.
    On the radius rods, the moog bushings are what I have now. Solid definately would not work there. I want to use a spherical bearing setup.
    Jan 2003
    1986 prelude
    charlotte nc
    i waan see pix
  1. 85 accord rear trailing arm bushings
    By Taylor Smith in forum Wanted
    Last Post: 12-08-2012, 12:46 AM
  2. Rear lower shock bushing part number
    By G. White in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-03-2012, 06:37 PM
  3. Vigor rear sway bar bushing question
    Last Post: 03-16-2009, 07:51 AM
  4. Prothane rear bushing kit fitment?
    By AccordEXI in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-10-2006, 11:56 PM
  5. Replies: 0
    Last Post: 11-26-2003, 10:06 AM
