Results 1 to 25 of 31
Thread: time for new motor
    LX User fijisac's Avatar
    Feb 2009
    1989 honda accord LX
    sacramento, california. 91sickness
    time for new motor
    well i finally did a compression test on my car 2day and the results have mad me mad for bout 2 hours cause i did a dry compression test and got 60 psi in all 4 cylinders. then i did to do a wet compression (dat when you squirt a teaspoon of oil through the spark plug hole, dis test will tell u if ur rings r bad.) i got 70 psi in all 4 cylinder. then i decided to cylinder leak down test. and i got 20% leakage in cylinder 1,3,4 and i got 60% in cylinder 2. so after a shit load of people telling me i should have never bought da car, i am now thinking bout wut 2 do with the car itself. well wut do u think i should do
    Re: time for new motor
    should try replaceing the head gasket and does it use any coolant? how many miles? burn any oil?
    get a civic
    get a civic
    nfs480's Avatar
    1989 Honda Accord SE-i
    Rogers, MN, USA
    get a civic
    I think you mean, fix the 3gee!
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    That seems like pretty solid leakage throughout the motor. Should be 120 per cylinder if im not mistaken. You probably do have a blow headgasket.
    '89 SE-i Coupe
    Awaiting Garage
    Just giving the kid shit lol......just fix the the head gasket lol and go from there...
    Feb 2009
    lol head gasket, i just changed dat bak in February and i'm not buring any coolent, or oil
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    I don't see how it ran with them numbers. Used motor is your best shot at this point if you want to keep it.
    SEi User ZackieDarko's Avatar
    did you warm the motor up first?
    i know it wouldnnt account for all that pressure loss but maybe it isnt as bad as you think?
    Feb 2009
    Quote Originally Posted by 88Accord-DX View Post
    lol i was thinking da same thing but i really want to rebuild da motor but i will have 2 c how much money i got
    i dont see how you could have that bad of compression if you dont burn oil... with numbers like that your rings would have to be shot and if that was it would be burning oil like mad and smoking lol... then again valve seals could be playing a big part of tho
    Feb 2009
    now that you think bout it, i have not seen any smoke while driving (even under load) but yea dats ture, if it was my ring then i would b blowing out black smoke, dis it hella strange, do u think dat the pcv valve could cause dis problem?
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Quote Originally Posted by fijisac View Post
    Rebuilding the motor isn't going to be cheap. Sounds like if you get the block bored out & get some oversized pistons & rings your might be good. The thing is, you have to mic the rod & crank to see if you can still use standard size rod & crank bearings.
    I will say, rebuilding a motor isn't for the average shady tree mechanic. It might look easy on paper & on the net, but if your not sure on what your doing, it might be a waste of money.
    Rebuilding my engine ran me about $1,200 for the engine alone, not including other parts I felt needed to be replaced. That was doing it myself with block & head work done by a machine shop.
    Feb 2009
    I will say, rebuilding a motor isn't for the average shady tree mechanic. It might look easy on paper & on the net, but if not sure on what your doing, it might be a waste of money.
    well dam, dats a lot for a rebuilt motor, i think dat idea is out, i just might get a used low mileage motor then
    does it smoke on startup for the first couple of seconds?
    Feb 2009
    well i just checked right now and it does not smoke at all but i do smell bad emissions tho, lol
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    If your valve lash is out of whack (to tight) than your leak down will be bad. It seems like if it ran something else might be the problem. Make sure your timing is correct also on the timing belt.
    Feb 2009
    well my timing is ok but i do need to check the valve lash
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    I doubt your valve lash is out of whack that much, but make sure when your doing a leak down test on any cylinder that the camshaft lobe isn't touching a valve on either the exhaust or intake at TDC on each cylinder your testing.
    Feb 2009
    well my instructor told me dat if there is 20% leakage in a cylinder, its ok, but i can head the air pressure from the valve cover and from the oil dip stick tube so i would think dat the ring are bad but i'm not blowing out black smoke, dis is very strange
    does the car drive and run fine? have decent power? if so i wouldn't worry about it much..
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    Lol you did open the throttle all the way for the test right?
    And as was said warmed it to operating temperature?
    Sounds like bent valve on the 60% imo
    did the people you bought it from say they just replaced the timing belt?
    And im betting it doesnt run real good if you decided to do a comp test right
    Feb 2009
    Quote Originally Posted by Demon1024 View Post
    well yes and no
    yes i did go WOT and it was warmed up when i did da test and the reason why i did the test was because my friend did not wanted 2 do it on his 5.0 so he told me to bring my car cause i was easier 2 do
    1ajs's Avatar
    slurpeepeg
    what kinda shape is the body in rust wise ect? it its in good shape i would say just hunt for a motor to swap in it not all that hard to do can be done in a afternoon or over a weekend
  1. Time for mega motor swapping
    By hondalude86 in forum Classic Honda Community Chat
    Last Post: 07-26-2012, 12:54 PM
  2. Motor time???
    By 3gn86lxi in forum Performance
    Last Post: 02-26-2006, 07:30 PM
  3. Mugen b20a-3g accord motor or 3g prelude motor!
    By adams86lxi in forum Classic Honda Community Chat
    Last Post: 01-13-2005, 11:01 PM
  4. Long time viewer, first time poster.
    By bc86 in forum Classic Honda Pics & Videos
    Last Post: 07-24-2004, 10:47 PM
  5. time to kill my 3gee ? or time to ....
    By bboipinoy112 in forum Classic Honda Community Chat
    Last Post: 07-31-2003, 12:22 AM
