Results 1 to 2 of 2
Thread: timing and valves
    Apr 2008
    timing and valves
    Hi, I am doing the full timing belt kit soon
    (Tbelt, 3 acc belts, valve cover gasket / grommets, water pump and seal, tensioner, cam seal, crank seal.
    Just did plugs / pcv. Wires seem good, Just seam foamed, doing cap and rotor / fuel filter / air filter. (i know i should have done plugs after)
    My mechanic is going to adjust the valves when he does the cover cause my valves are chattering the slightest bit under some rpm.
    Car is basically stock except for magnaflow muffler.
    What should I have the timing set to? I dont mind using better gas is the car will run better.
    Anything we can do with the valves while he is in there ?
    Vanilla Sky's Avatar
    1999 Penalty Box
    Re: timing and valves
    Every motor will be slightly different. Start off with the timing on the label under the hood and advance slightly from there. I had a carbed car that would take about 2 degrees of advance before it pinged, even with premium. One of my friends had an LXi that wouldn't ping at full advance with regular. You're really only going to get it set perfectly on a dyno, so just start with stock timing and bump up until it pings on regular then back down.
  1. Timing and Valves
    By kukerdan in forum Forced Induction
    Last Post: 07-16-2009, 10:22 AM
  2. B20 valves
    By rjudgey in forum JDM B18A / B20A Swap Tech
    Last Post: 07-26-2006, 01:55 PM
  3. valves
    By gofast in forum 3geez Accords
    Last Post: 04-10-2004, 07:44 PM
  4. valves
    By tyne89 in forum 3geez Accords
    Last Post: 11-11-2002, 01:14 PM
  5. Valves
    By rallyeNate in forum 3geez Accords
    Last Post: 09-09-2002, 12:16 PM
