Results 1 to 9 of 9
Thread: How to remove the shock from your frozen suspension
    DX User clark_486's Avatar
    Apr 2008
    1986 Accord DX
    Maine
    Things you will need:
    1. A 10x1.25 40-50mm Bolt [Known to fit 86-87 models] you may want to take the bolt to the store to verify size and thread. Make sure it is threaded the whole length of the bolt. Also you need a scrap piece of steel about around 1/8" thick and maybe 3/4" x 4"-5" long
    2. Some kind of anti-seize grease [Graphite grease has worked well for me]
    3. PB Blaster to help free rusted bolts and nuts.
    4. If you see that a bolt or nut is rusted you might want to use 6 point sockets to remove them as 12 point sockets can slip and destroy the bolt head or nut making it almost impossible to remove w/o permanent damage.
    5. If you run up against a bolt or nut that is frozen with rust a LP torch will sometimes work to heat up and allow removal. Warning: be careful of the brake lines if using heat. Heat can be used with PB Blaster or other penetrating lubricants. Be careful when using the two together as most are highly flammable.
    6. A jack, jack stands, and a friend to help hold stuff and such.
    If your car has a lot of rusted frozen bolts and nuts on the suspension my friend and i developed a way to easly remove the shock from the fork with out cutting the fork bolt or removing the fork from the car.
    first remove the tires and outer CV shaft nuts. [If you cant get them off its not a big deal however you have to take special care that you don't dislocate the CV shafts inner or outer joints.]
    Next remove the upper arm from the frame.
    [Drivers side: You will need to move the wiper motor out of the way to get to one of the nuts. Remove the 4 bolts and then slowly push the wipers up by hand. As you move the wipers toward the end of their normal travel the motor should be able to be rotated clockwise against the firewall. once it is in 11-12 o clock position you should be able to remove both upper arm nuts.]
    [Passenger side: You will need to move the black 'mystery box' with the vacuum lines coming out of it. Remove the two bolts from the firewall, remove the wire cover from the far left side, remove the two wire harness' from the black box, pull the box up out of the retainer on the firewall and place the box near the intake (usually upside down so as not to stress the vacuum lines) The two upper arm nuts should now be visible. Remove them.
    Once the upper arm is loose from the frame remove the outer CV spindle from the wheel hub. This will protect the CV shaft joints later on.
    Now remove the brake line brackets from the shock and control arm. Also Remove the Pinch bolt from the fork.
    Next Remove the three nuts and washers from the shock top located on the shock tower. You may want to remove the plastic shock top cover for increased visibility.
    You should now be able to tip the shock away from the car. If it wont clear the fender or you have trouble getting it out of the shock tower have someone lightly put weight on the outside edge of the rotor and pull the shock down and toward you.
    Once the shock is loose on top get your 40+mm 10x1.25 Metric bolt and carefully thread it into the fork on the threaded side. This is the opposite side from the original pinch bolt. after its been threaded most of the way in, stick the scrap steel in the gap in the back of the fork and tighten the bolt till the steel stays in place. Now ratchet the bolt tighter. This will spread the fork out enough so that you can turn the shock part way and it seems loose enough to pull out. Then back off the bolt untill its back in the threaded part of the fork and not touching the side of the shock.
    you should now be able to pull the shock down out of the fender well and out of the fork.
    Before you put anything back together take your anti-seize graphite grease or something that will discourage the nuts and bolts from seizing up and coat any studs, bolts, splines, and nuts that where removed. Put some on the base of the new shock to aid installation and future removal.
    Now put everything back in reversed order that it was taken out.
    http://www.cardomain.com/ride/3052003
    1986 USDM Accord DX
    Jan 2003
    1986 prelude
    charlotte nc
    Re: How to remove the shock from your frozen suspension
    Hmm thats a great write up iv never had one problem.
    But u know wat works best for me on suspension pieces and brake pieces any bolt that doesnt come out i take the whole arm and take it to a mechanic and i tip them 5 bucks and they impact it out . Best thing to do ever ,
    Apr 2008
    1986 Accord DX
    Maine
    the salt is hard on the metal around here though.
    1986 USDM Accord DX
    Quote Originally Posted by clark_486 View Post
    Good write up. Thank you. I'm not quite getting the trick in this paragraph though. I'm thinking there is some kind of lever or cam action prying the pinch open, but I can't picture it in my head. I don't suppose there's a possibility of getting pics is there?
    Apr 2008
    1986 Accord DX
    Maine
    basically you want to put the 'removal bolt' in backwards on the threaded side of the pinch and put a piece of metal in the gap so it doesn't just go thought the pinch. this will force the pinch to open.
    hope this helps. ill get some real pictures when i do my damper again, some id10t left the bump stop and dust shield off one of my damper.
    1986 USDM Accord DX
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    MY civic came from the Midwest; replacing the rear struts (which I did recently) was a damn PITA. Bolts rust frozen in the bushings - 3 or 4 heads broke off - I have to cut them with a saw. I even had to cut the top nut -rust frozen- Interestingly enough, replacing front struts in the same car was like normal (no frozen bolts) But the rear of that car has been painful in terms of rusted bolts
    Definitely use some anti-seize throughout the bolt or at the very least thick grease. Grease has worked out OK for me; I was able to see traces of it after 5-6 years.
    Ah, very clever. Thanks!
    Jul 2002
    a pile of lawn ornaments
    Newtown, CT
    I like it, just basically using a shim and a little mechanical separation to free it up. I use to take the route of removing the shock with the fork as one assembly, then remove the bolt that holding the fork closed on the shock base. Then I just grabbed a hammer and cold chisel and tapped it vertically up or down that slot to separate the fork.
    I'm definitely going to try your method next time though because I think it'll prove to be a much easier way. Big ups for you for the secret.
    -Mark D.
    Apr 2008
    Atlanta, GA
    Now I got it; nice move.
  1. Parking Brake Adjustment Bolt Frozen
    By Ajbent86 in forum 3geez Accords
    Last Post: 05-23-2011, 04:12 PM
  2. damper fork bolt frozen
    By jayshonda in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-19-2005, 09:21 PM
  3. Frozen caliper on Parts Car
    By FatDave in forum Classic Honda Community Chat
    Last Post: 09-19-2004, 07:21 AM
  4. Bilstein Sport Gas Shock? - Suspension gods help
    By SteveDX89 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-13-2003, 06:15 AM
  5. fuel line frozen?
    By dirty89lx5sp in forum 3geez Accords
    Last Post: 01-30-2003, 06:58 AM
