Results 1 to 7 of 7
Thread: Fuel Filter
    Jul 2002
    Fuel Filter
    I NEED TO KNOW WHERE THE FUEL FILTER IS ON AN 89 LXI 4 DOOR THANKS
    89 Accord LX Coupe
    Vernon BC CANADA
    behind the rear drivers side tire....remove it and then you should be able to see it ...theres probably a cover over it still...
    there also might be a secondary one....if there is on you car then its in the engine bay...right near the brake booster....im not sure if the fuel injected models have one there or not....Someone else will know.
    Ben
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    On my 89 LXi sedan it's mounted on the firewall on the passenger side about a foot down from the hood. Do you already know how to change it?
    Mike
    Nov 2000
    Yes, definitely passenger side on fire wall. Sits in a bracket assembly with two high pressure hoses bolted to the top of it.
    89 Accord LX Coupe
    Vernon BC CANADA
    Oh so iguess that the FI.s are differnt than the carbed??
    Ben
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Yeah, you carb guys have an extra filter. And ours is under much higher pressure so it's design is a lot different.
    Mike
    OldSchoolSwap's Avatar
    88 Hybrid Accord LX-i
    Miami, Florida
    Not an accord but mounts in verry similar way. http://www.c-speedracing.com/howto/fpgauge/fpgauge.html
    http://vtecnos.tripod.com
    Member Since 7-9-01
  1. Fuel filter help
    By SFCA1987lx in forum 3geez Accords
    Last Post: 02-04-2012, 01:48 PM
  2. Fuel Filter? Fuel pump?
    By Bass Man in forum 3geez Accords
    Last Post: 05-19-2008, 03:38 AM
  3. fuel filter !!!HELP!!!
    By FORFREE in forum 3geez Accords
    Last Post: 05-20-2006, 03:26 PM
  4. hepl cannot got fuel line off fuel filter
    By 88vert in forum 3geez Accords
    Last Post: 02-04-2004, 09:20 AM
  5. fuel filter help
    Last Post: 06-23-2002, 05:41 PM
