Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
Thread: help help help
    DX User ps2man21's Avatar
    Jul 2009
    Re: help help help
    yeah thats what i was thinking
    soooo
    yeah
    gonna get right on it
    hope it fixes the problem
    ill keep you updated
    Re: help help help
    even doh i am on vacation all week I found time to search for you.
    Standard front end check:
    1: jack up one side of the car until one tire is off the ground. The other side tire must be on the ground. I use the jacking point under the doors.
    2: grab the tire in the air at the 3 and 9 o clock postion and shake/rock back and forth. slow at first. You might need someone to help look underneath. This checks tie-rods,steering rack etc. start kinda slow and work your way up a little harder. Your looking for loosness at the joints. Use common sense of course the steering wheel will move or the other tire may move if you shake the shit outta it.
    3: Grab the tire 12 and 6 o clock. Rock back and fourth.This checks the wheel bearing and ball joints(upper and lower) and upper links(bushings). There should be no play in the wheel bearings.
    4: this check might show ball joints/upper link a little better. Use a pry bar under the tire at the 6 o clock pos. pry up look for slop ,looseness while prying. The upper link ball joint and bushings near the body are what your looking at.
    This is your basic "front end check" any good mechanic should know. It works for all makes and models of cars.
