Results 1 to 7 of 7
Thread: any reason this wouldn't work?
    Feb 2004
    89 accord lxi
    down by the bay
    I was thinking about using this as endlinks for my suspension techniques front bar, instead of the 4 bushing sandwich it uses now.
    I'd attach the studs to the bar and lca with washers to fit in the bevel and a nut with a jam nut to keep it from coming loose. I know the specs don't include a load rating, but at least it's steel.
    Re: any reason this wouldn't work?
    I dont see why not.Tricky little part with the ball joint built into it
    Ichiban's Avatar
    North of You.
    Will the 30 degree swivel provide enough range of motion to avoid binding? It seems like it would only have 15 Deg per side?
    ICHIBAN!
    "Now, even more better!"
    Feb 2004
    89 accord lxi
    down by the bay
    hmm, I think the bar and lca would have the most misalignment when the suspension is at full droop? I thought the arcs matched fairly well. I guess I'd need to take the springs out and move the suspension through its full range to check.
    Ichiban's Avatar
    North of You.
    Quote Originally Posted by Strugglebucket View Post
    I'm just curious because the axis of rotation of the LCA and stabilizer bar are perpendicular to each other.
    ICHIBAN!
    Jul 2002
    a pile of lawn ornaments
    Newtown, CT
    not only the load rating, but the vibration dampening of the 4-bushing sandwich, as opposed to this which would essentially be a bushing-less setup. The anti-sway bar endlinks take a beating, and I'm not sure that ball-joint setup would be up for the job. Just IMO though.
    What is the goal for doing this? Just to reduce the slop associated with the stock endlink setup?
    -Mark D.
    Feb 2004
    89 accord lxi
    down by the bay
    Yeah, less slop and (assuming the joint doesn't run out of pivot) less binding.
    The rear st bar has a nice rod end on it in combination with 2 bushings and it's easy to swap the bushings to metal. I've never liked the way the front is set up with a bolt that just sort of mushes around.
  1. Wouldn't You Know!
    By treadhead 1952 in forum 3geez Accords
    Last Post: 10-22-2004, 01:04 PM
  2. 89 accord wouldn't idle
    By jim89 in forum Carburetor Tech
    Last Post: 03-04-2004, 06:47 PM
  3. Car Wouldn't Start
    By Goldfinger89 in forum 3geez Accords
    Last Post: 08-19-2003, 04:26 AM
  4. Wouldn't metal or aluminum be bad for a CAI
    By c20v6turbo3rdgen in forum Performance
    Last Post: 07-19-2003, 10:42 PM
  5. Car wouldn't start.
    By Grant2k in forum 3geez Accords
    Last Post: 11-07-2002, 06:53 PM
