Its time to part with a few things to make way for new projects.
first up-
Full dual weber DCOE side draft carb setup. this will include pretty much everything you need to install this on an a20 accord.
2 weber DCOE 40 carbs
1 top mount dual spring linkage
4 o-ring isolation mounts + nuts, bolts, springs
4 air horns
2 oval k&n style air filters
1 custom made aluminum intake manifold
I had these on my car for a little less than 3 years. everything worked great. I would recommend putting a re-seal kit in the carbs just because they do have some miles on them since the last rebuild (when I first installed them)
If you live in a very cold climate and plan on using these I would recommend installing a block heater. During cold winter mornings (I would say anything less than 20*F) these carbs will fuss when trying to start a dead cold engine. Once the car starts and warms up a bit it runs and drives as normal. With a block heater there is no problem.
SOLD
next I have a brand new, never mounted intake manifold for dual DCOE's.
I actually had two manifolds made at the same time. this is identical to the manifold I used for my DCOE setup listed above.
$200 shipped (conUS)
and last I have a brand new, never installed pacesetter header. I bought this from a member here several years ago. It has been coated (not cheap spray paint) with some kind of header coating (i think it is jet hot, blue in color) this has never been used by me or the previous owner.
The ball and socket joint has been removed and a standard two hole exhaust flange was welded on. You will probably need to have section made that goes between the header and cat with a flex joint in the middle. This is something any exhaust shop would be able to do. As is, this will not bolt up to the stock exhaust.
SOLD
the air filters in the pics are not what I am selling with the DCOE package. the ones in the pics didnt last long before they fell apart so I switched to the k&n style filters.
