I decided to make my first thread. I have been lurking on this forum for sometime now building my knowledge, aka trying not to sound like a fool. Ok so I will jump right into the matter at hand. I have a 1980 Accord coupe. Im in the middle of doing a weber swap. The old carb is gone and out of the way, waiting patiently to be smashed via a massive rock. No where in the weber install did it say to fill the coolant hole. Is this something that should be done no matter the case? The hole is not on the firewall side of the manifold its closer to the engine. Is this even a coolant hole? It seems that a ton of crap comes off with the old carb....Im a little nervous to see all that stuff disapearing. What exactly needs to be hooked directly to the carb? I have noticed a couple different meathods. Also what needs to be plugged? What can I trash? Im a bit scared.....I dont want to crap something Im going to need and then not be able to find it again.......HELP! Oh...yea my HOA is loving this project![]()
