1986 Accord LXi 3-door
1968 Chevy C20
speaking of 4g accord coupes i had the pleasure of removing the window visor things off one yesterday, prolly the 1st and last one ill ever see over here!
lol...
got a new Plus start 525CCA battery today.. and some battery posts...my old one would die...then 2 seconds later work again and sometimes now...push starting was getting old lol...then today
i was driving down the aly...notice my tach was at 0... was like WAT then it went 0 to 3k 0 to 3k then 0 to 1k 0 to 1k 0 to 1k 0 to 1k 0 to 1k which made me confused..anywho i got out of car walked down aly and heard a werid
eeeeee sound was like WTF is that... walked back and it was the horn... O.o the seat belt motors were moving VERY slowly back and forth and window motors were barely working all the lights were dimmed down to nothing... got it home while driving the battery light was on , oil light was flickering and about 40 relays were clicking...
poped my geos battery in it everything was soild alternator was putting out a beautful 14volts so was like ok... i then tested the old duralast POS battery... was bounceing between 4volts and 17!!! volts :| WTF!!!!!! ... it was also blistering hot!!! ... im sure i will here on the news tomorrow
" battery explodes at kmart! "
anywho spent $50 on a new battery now the car works... and seems to run better
4g has been rather failing today lol... well went out to unplug the 02 sensor to see if that helped any with bad gas millage ...ended up ripping out the wires which blew the ECU fuse... replaced the fuse unpluged ripped harness.. then realized it was missing a vacuum hose so got that capped... then it overheated tonight in cold as shit weather WTF...then got a flat tire =/ ...this car. it causes me rage lol... <3 my pos geo
i'm starting to think you're cursed. you're probably cursed for hanging out on 3geez without actually owning a 3geez anymore. its haunting you.
lol my 3gee had more bad luck then this car.. lol i could never even take my 3gee out of town with out having to be towed back home
Hey !
Bought my first Car.. Honda Accord CB7 and I've been having problems with the cluster.
First off I found that the RPM meter cable was off.. then when I started the car to test it it would bounce up to 2 and then stay there.. and wouldn't move again even if I rev my engine.
Then recently after cleaning my throttle body I went to turn on the car but forgot that the positive terminal on my battery was off and I swing to turn it on like 4 times then I remembered it was off.
After that everything got worst.
My gas meter read full.. it's suppose to be half cause that's how it was all the time
The RPM stayed at 2, nothing changed there..
and now the Speedometer bounces at 20 then goes down to 10 and stays there and sometimes moves up and down when I rev my engine...
I've checked the thermostat wire which is clean and I've checked my fuses under my steering wheel.. which are also good..
Can someone help me with this problem? It's been bugging me and I really want to get my car up and running perfectly.
it's my first ever car so everything is bothering me alot lol
Thanks for reading !
^Hello Domonic CB7 welcome to 3geez.com but we are a website specialied in 1986-1989 honda accords. Cb7tuner.com is a forum where they can help you out with your cluster problem.
