I need to find the three gasket in the redline kit for 32/36 weber!!! looked around but can't see anything has anyone ever bought replacement ones??? and if so from where!!! got a vacuum leak coming from the bottom gasket to the manifold!!!
3geez is F**kin Awesome!!!
Give Carbs Unlimited a call. They can get you any gasket or little piece you need.
www.carbsunlimited.com
Or if you're impatient and partly insane like me you can go to your favorite parts store and get a sheet of gasket material to make your own gaskets with. Those carb base gaskets are pretty simple really.
But before you do that, make sure the bottom of the adapter plate (and top of the intake manifold) is perfectly flat. They are cast plates and may have imperfections. You can use a file to remove any high spots. Also make sure the bolts aren't too tight as they can warp the adapter plate.
C|
