For control arm bushings I don't think it would have to be bonded to any sleeves. The poly bushings on my truck for example just slide into the control arm and the sleeves slide into the bushings. The joints do have grease fittings though so that might be the difference. Also, OEM type mounts and bushings always seem to be rubber not poly. Rubber probably wouldn't last as long as poly in a slip fit type application, especially without regular lubing. And OEMs want to minimize maintenance requirements. Anyway I think there are some poly bushings that fit the lower arms aren't there?
For poly engine mounts, they would have to be designed in such a way that the poly is completely captured. Just like the B swap mounts elsewhere in this forum. It eliminates having to bond the poly to the metal and it also makes it so that just the poly can be replaced if it wears out. If you really wanted to bond poly to a metal plate or some such, it might work if the interface surface was textured somehow, like knurling or maybe just coarsely machined. With the poly then poured onto it. It would take some experimentation to get right.
For making motor mounts economically we don't really have the right equipment. The best way to make mounts is to cut the pieces out of say 1/4" steel plate, and then bend (if needed) and weld the pieces together. Plate is best cut with a water jet or laser, which we don't have. It can be done on a mill but it's slower and wastes more material. We don't have any bending machines either. I can weld but that won't help much without the other stuff. We mostly make machines and fixtures for manufacturing, so little if any forming or welding is required. Most everything we make is milled.
Control arm bushings would be easier if they don't need to be bonded to anything. A mold could be machined out of aluminum and casting poly poured in. If it's done right, little to no machining should be required.
C|
The last nylon job I did was with this oil filled nylon that's bright green. The chips were light and fluffy, and colored neon green. When I was done the base and table of the mill were buried in bright green fluffy chips. It looked like a demented cross between a Terminator robot and a Sesame Street monster!
Funny stuff.
C|
energy suspension makes a series of universal poly motor mounts which i think can be adapted over with some work, doesn't the front cross member unbolt from the car? if it had threaded bushings welded in in the correct places some of the universal mounts could be used to replace the front mount easy.
so wats the verdict wats the best way to cut them iv read alot but not sure havnt cut yet
To make a round bushing that stands out short would all u guys agree a lathe is the best way
If it's the kind of bushing I think you're talking about (something like the link below) you could use a mill or a lathe. Just depends on availability and preference. I make lots of round parts on a mill because I don't have a CNC lathe. It might also depend on what kind of stock you are starting with. On a mill it's usually easier to hold on to rectangular things, and on a lathe it usually easier to hold on to round things. But you can do both on either.
But if you are really serious about making poly bushings I think it will be easier/cheaper to have a mold made and then use castable poly compound to mold the parts. Squishy materials like poly are not fun to machine. Which means that whomever is doing the machining will want more money.
http://www.energysuspension.com/univ...isolators.html
C|
