Hey guys,
Couple of days ago my drivers' side window regulator decided it didn't want to live anymore and quit on me. Problem I have is the window is stuck approx halfway down, can't move it in either direction no matter what I do. This is annoying, especially since we have had a very rainy summer here this year.
I had planned on going to the junkyard tomorrow to fish for a new one to replace this with but I've run into some questions.
How does this come out? I've done regulators before, I see the bolts that hold it in (looks to be about 3), and the little window at the bottom left corner to remove it through, thing I am wondering is how the window track separates from the glass and/or the unit comes out without effin' up something else.
It looks to have a scissor motion type of lever inside hooked to the regulator and I can't see enough to figure out how to remove it. By my own admission, I didn't spend a great deal of time messing with it since I had other things to fix today. Anyone have an exploded diagram of the inside of the door I could look at?
Also considering the idea that it might not be the regulator even though all of the other windows work properly. Checked the switch panel, no problems there, not sure if that window alone would have it's own fuse or not. Seems kinda dumb if it does. Have I missed anything before I put myself through a lot of trouble getting this apart?
Is there a way to manually move this window up or down, assuming to get the glass off I'd have to remove a few screws from the channel the glass sits in?
Any help is appreciated, thanks!
Z
