where should i put the valve cover sealant? around the entire lip or just in the corners or on the rounded parts? I'm sayin this cause i just popped mine off and the gasket looked almost brand new but it had sealant on 2 sides of the gasket and it was in tatters so im prayin that caused the leak and it's not somethin else.....anywho thanks for the help and it also had a little bit of oil on the grommet on the far left if you're looking at it from the front....the grommets were all cracked and dried out also...so it looks like whoever did it last just reused the old grommets
