I want to know If I can pull my Driveline and put in a Honda S2000 Driveline in ? Would my mount point be different?
s2000 is rwd and accord is front wheel drive so yes there would be a difference
https://www.3geez.com/forum/showthread.php?t=69336 my car thread
Would it be possible with some mod?
Yeah, with a sawzall and a welder, you can make ANYTHING.
HOLY SWEET CHRIST!!! look at the top of ur screen, ya see that thing that says search, click it, type, etc... do a little research, find things out on your own. ive seen this question pop up over a hundred times.
to do this it would take a TON of money and take FOREVER to do. im not sayin dont do it, cuz i think it would be totally flippin sweet to see, but a lot of people ask this and it just virtually never gets done...
there is 1, ONE rear wheel drive accord to date right now and it took alot fo work and knowhow to get it running, mind you the motor is in the back aswell so a front engine rear wheel drive 3g has never been done, if your asking about if it could be done then sadly you dont have the know how to do the amount of work that is needed. not trying to be a dick, or be blunt, but its the truth
it would be a lot of work, you would have to make room for the trans and driveshaft under the body, run an all new exhuast, make up a new driveshaft, find a rwd axle that fits up, find a way to re mount the front wheels, re do the wiring harness, possible obd2 coversion i'm not sure on that, and well its gonna cost you almost as much as buying a used s2000 but yes with the right amount of money and time if you truely want to you can do it, its just gonna take a while
Front wheels would mount the same as they do now, just sans the axles.
The rear could be back halved with the IRS out of something like an FC RX7 or a Miata. Trans hump would have to be fabbed, and mounts made, but it's possible with a lot of skill.
BTW, if you had that skill, you wouldn't be asking, you'd be working on it.
hahaha..
I think your question been answered..
My Build Thread
Am I the only one to wonder what the hell the H22 has got to do with the S2k?
x3... you mean f20c? :-\
dead white and blue
I dont want to change the FWD to A RWD, I just want to see if the motor Fits. I want to keep my car FWD.
Aaaaaaaand we're done.
