Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
Thread: Vacuum leak + Smoke
    Re: Vacuum leak + Smoke
    Brake booster is probably leaking. Master cylinder is probably leaking into brake booster. Brake fluid is getting sucked into the intake manifold. Hence the smoke and vacuum leak at the same time.
    Sep 2009
    86 Accord LXi 5sp, 293k
    Montgomery, AL
    Could your pcv be sticking and causing excessive pressure in the crankcase? After shutdown you here like a vacuum release maybe it is shot opening and not closing properly or a leak in that line. Are you still running the line from the valve cover to the plastic intake tube? I would doubt it would be your vacuum advance if it is running well. Brake booster also holds vacuum.
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    I very seriously doubt its my brake booster, it sounds to be coming from the left side, near the PCV/Distributor side of things.
    Quote Originally Posted by kentwat View Post
    I dont think its my vacuum advance either, I'm starting to believe its the PCV as well. I do hear a pretty loud woosh after shutting the car off actually, but i was told that was normal about two years ago by someone whos worked on hondas for his whole life.
    '89 SE-i Coupe
    Awaiting Garage
    2drSE-i's Avatar
    Oklahoma City
    Oh keep the ideas coming though, i really appreciate the input.
    '89 SE-i Coupe
    Awaiting Garage
    2drSE-i's Avatar
    Oklahoma City
    i guess ill work on it tomorrow.
    '89 SE-i Coupe
    Awaiting Garage
    have you looked at the hard plastic pieces of the pcv valve? they get old and crack
    2drSE-i's Avatar
    Oklahoma City
    This, turns out, was absolutely the problem. I'm fairly certain my PCV Valve has been clogged/not working for two years, and it finally found a passage to vent through, causing the horrible whistle. I used pliers to try to hear the "Click" a healthy PCV valve makes. I heard the click, but the whistle also disappeared. Hooray for 10 dollar fixes!
    '89 SE-i Coupe
    Awaiting Garage
  1. Oil Leak & Smoke
    By syclinsam in forum 3geez Accords
    Last Post: 04-12-2009, 03:17 PM
  2. how do i know if i have a vacuum leak?
    By Dennis in forum Carburetor Tech
    Last Post: 05-12-2004, 12:43 PM
  3. 86accord oil leak/smoke prob
    By 86accordlxsmokes in forum 3geez Accords
    Last Post: 10-15-2003, 10:46 AM
  4. vacuum leak?
    By lewis74 in forum 3geez Accords
    Last Post: 09-09-2003, 06:17 PM
