Results 1 to 7 of 7
Thread: How to retorque the head?
    So I'm thinking I need to retorque the head on my EK1. But I was confused about how exactly you're supposed to do it...
    Are you supposed to loosen the head bolts and retorque them just as if you were installing them?
    Or are you supposed to just add 1-2 lb-ft and just tighten them down a bit more?
    Maybe this is a dumb question, but I just wasn't sure. Didn't see any procedures or anything... Never retorqued a cylinder head before, just want to avoid another possible blown head gasket.
    Re: How to retorque the head?
    im pretty sure all they do is re torque it to its supposed tore setting, that way you will know if it got looser or not
    I'd avoid taking the tension off the head gasket by loosening the bolts. Just tighten them up.
    yeah yeah what he had said....
    do not loosen, and in case of an oil leak an extra click on the torque doesnt hurt just do it all in proper sequence
    OK thanks guys. Just wanted to be sure.
    carotman's Avatar
    Montreal South Shore
    When retorquing, you have to loosen them a bit, you don't have any other choice.
    This is because the dynamic friction coeff. is lower than the static friction.
    This means it takes MORE torque to move a static object than it takes to keep it in movement.
    When torquing bolts, you have to make sure the bolt is actually moving when you reach the desired torque.
    http://www.fordscorpio.co.uk/manual/...TDICHBolts.pdf
    ^^very good point its like when u have a really tight bold you tighten it before you loosen it and it sometimes comes undone easier
  1. Fixed head lights face off popup head lights
    By Tommy AC89 Thailand in forum Interior & Exterior Care
    Last Post: 03-17-2009, 06:46 PM
  2. Rebuilt 2.0 Honda Cylinder Head Accord W/ Head Set
    By 88accordSF in forum 3geez Accords
    Last Post: 04-16-2007, 07:36 PM
  3. stock rebuilt head, or port n polished head, opinion poll
    Last Post: 03-14-2007, 03:36 PM
  4. Need help with head or head gasket
    By Forgar_88 in forum 3geez Accords
    Last Post: 03-11-2004, 08:48 AM
  5. EFI head vs. CARB head
    By pric in forum 3geez Accords
    Last Post: 11-25-2002, 05:57 AM
