Results 1 to 8 of 8
Thread: Sound coming from front end!
    Aug 2009
    After I make a turn...don't think it matters which way I turn...I get a pulsating sound that increases with acceleration from I think the drivers side drive line. Do I have bearings? u-joints? Don't really know the parts of FWDs
    I have only worked on RWD vehicles....1st FWD for me....
    any help would be great!
    May 2008
    los angeles
    Re: Sound coming from front end!
    Quote Originally Posted by kwmowery View Post
    well if its only on the turns and its more of a ticking sound... then its your cv joints... if you can, post a vid and ill let you know
    -Tom
    1988 4 Door Lx-i 5-speed
    364,XXX and counting :]
    Aug 2009
    its more of a sqweek.....sqweek.....sqweek....sound....that increases with speed.
    I do not have the capability of recording the sound currently.
    May 2008
    los angeles
    ok... is it more of a nails on chalkboard sound? if so then you probably need new brakes... its hard to tell
    -Tom
    Squeak, or creak? When I think of a squeak, I think of a mouse. Creak, I think door.
    LX User SOHC's Avatar
    Jul 2009
    1987 Honda Accord EX-i
    CANADA
    That sounds like the Brakes, I may be wrong.
    LXi User headbanger's Avatar
    Dec 2007
    1989 accord lxi
    waynesville,nc
    It probally has the cheaper pad which will make a squeaking sound after they crystalize.Spray them real good with brake cleaner then drive it mash down on brake just a little bit an see if it stops if it does just replace pads with a mid grade version from ur local autoparts.Usually if it is a cv joint going out it makes a clicking sound when u turn wheel.while in motion.
    May 2008
    los angeles
    Quote Originally Posted by headbanger View Post
    it probally has the cheaper pad which will make a squeaking sound after they crystalize.spray them real good with brake cleaner then drive it mash down on brake just a little bit an see if it stops if it does just replace pads with a mid grade version from ur local autoparts.usually if it is a cv joint going out it makes a clicking sound when u turn wheel.while in motion.
    +1
    -Tom
  1. Chirping sound coming from engine somewhere.
    By honda crew in forum 3geez Accords
    Last Post: 03-13-2012, 05:54 PM
  2. Rattling/Knocking sound coming from engine...
    By mrma5b in forum EFI Tech
    Last Post: 04-10-2011, 03:40 PM
  3. clunk sound coming from front of car!!!
    By gfrg88 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-18-2006, 07:40 PM
  4. Smoking coming from front of car.
    By Mike's89AccordLX in forum 3geez Accords
    Last Post: 12-13-2002, 12:06 AM
  5. Front wiper fluid not coming out
    By 87DXHatch in forum 3geez Accords
    Last Post: 05-03-2002, 12:51 AM
