Results 1 to 16 of 16
Thread: DIY poly motor mounts
    3gmodifier's Avatar
    88 Accord LXi (sold) / B20A equipped 89 Accord Coupe (2.0Si replica) 2001 Prelude SH H23A Race Car, Track Orientated semi-built 2003 S2000, 2009 VW CC Turbo, 2007 Chevy Tahoe, and a damn 2005 Ford 500 lol!
    moreno valley, ca
    Alright, i know it sounds kinda ghetto, but i decided to make my own poly mounts. i had to pull my motor anyways and while it was out i went and bought some 3m 100% polyurethane adhesive. the stuff used to glue in windsheilds. i filled in the empty voids in the left, and rear mounts, and the rear upper torque mount. it took 3 days to fully cure.i didnt want it to be too hard because of the extra stress on the axles and averything else but after it was done, it was perfect. i have a friend with a 4th gen with hasport poly mounts and my end result was about 10% stiffer and a hell of a lot cheaper. i only spent $18.99 on the glue. he spent $275.00. i win! the drive is incredable. the cabin has a considerable incriece in vibration but i dont care about that. my build is more of a useable daily driven 2.0Si replica, with balls to back it up. the throttle response is insane. made my clutch work a bit more touchy but thats the way i like it. and when just cruising, you step on the gas and it goes. no more torque engine movement lag. very simple and very rewarding.
    3gmodifier(aka)JDM WHORE!
    Re: DIY poly motor mounts
    i still need to do this ^ i can feel the engine tilting back when i step on the gas (N)
    3gmodifier's Avatar
    moreno valley, ca
    yeah go for it. big differance on and cheap side
    SEi User turabaka's Avatar
    Aug 2007
    Boise, ID
    Awesome dude. Definitely worth the effort.
    I filled all mine with poly when I tore out my motor and replaced all the mounts. Made things a lot more solid. I spin the tires coming out of corners while I'm autocrossing now.
    3gmodifier's Avatar
    moreno valley, ca
    nice! its kinda cool knowing that i am not the first to try this. did you do all the mounts or just the damaged one?
    Aug 2007
    Boise, ID
    Quote Originally Posted by 3gmodifier View Post
    All of them. I ended up replacing every mount, and filling them all with poly.
    I didn't want to have a repeat of the last time I broke a motor mount.
    sheared the damned L shaped bracket for the side motor mount right off the block. Good times.
    ive been meaning to do this also, i remember just beefing up my dog bone mount some how and i noticed a difference lol
    now im going to do this....i need to do this. I only got the custom front mount and the dog bone filled...so i need to get the others done to..
    DO IT NAO!!! i expect to see pics within the hour of it done or
    LOL.....you see it......look into the white youll find it LOL
    LXi User CzEcHy's Avatar
    Jul 2008
    89 Accord LXI
    Gulf Breeze, Florida
    I bought some new motor mounts, would it be advised to fill them or just leave them as is?
    Would it even make a difference?
    Aug 2007
    Boise, ID
    Quote Originally Posted by CzEcHy View Post
    Like I said. I did it with all new motor mounts. It makes a huge difference, but unless you're racing the car I wouldn't do it. The interior vibration gets a bit worse. The only reason I did it is because my car sees about as much time autocrossing as it does being driven on the street.
    Jan 2003
    1986 prelude
    charlotte nc
    Yea i did al my except the dog bone im thinkn of , makin that one with heim joints , see if i can ?
    how did you do the dog bone one....i ran out of poly before i got to it
    Feb 2004
    89 accord lxi
    down by the bay
    I think the dogbone makes the biggest difference, you should definately fill it.
    If I remember right I used a dogbone from an automatic because the bushings were easier to fill.
    AZ
    i keep thinking this is going to be a diy thread...
    dead white and blue
  1. Alternative poly engine mounts
    By cygnus x-1 in forum Restoration & Custom Fabrication
    Last Post: 01-31-2018, 11:26 AM
  2. b20 motor mounts?
    By Spencer in forum 3geez Accords
    Last Post: 07-20-2009, 09:58 PM
  3. motor mounts/tranny mounts
    By powderkey2 in forum 3geez Accords
    Last Post: 09-12-2006, 08:34 AM
  4. DIY Poly motor mounts
    By dillirk in forum Performance
    Last Post: 03-07-2005, 11:46 PM
  5. Some New Motor Mounts and NOW......
    By NeubJ in forum 3geez Accords
    Last Post: 11-12-2003, 10:32 AM
