so I have a leak from somewhere under the hood that is getting onto the main serpentine belt and when you start the car it squeals really bad. I know its the main serpentine because if you don't give it some gas when it first starts up it will bog down and die. I have narrowed it down to ps fluid, but i can't find the leak anywhere.
I have already checked the ps rack, but its too low to get onto the belt. I also know that its the main serpentine because after driving around for a while there is fluid on the hood when you open it up... But i inspected the lines and can't find anything, any ideas what to check replace, and the easiest way to replace them???
