Page 3 of 3 FirstFirst 123
Results 51 to 69 of 69
Thread: What's the best tire size for a 3g?
  1. #51
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    Re: What's the best tire size for a 3g?
    ive had 205/60r/14's on my sei's a while back that were mirada's not really a good tire, i had to get this last set was fuzion Hri's b/c my father picked up 2 tires that were good from work, they are 185/60r/14 there pretty good all around and tread life is decent, will go back to the 205's i want 215 but 205 might be pushing it for the sei rims
    3Geez resident body man
    Owner of Wreck-less auto body
  2. #52
    so they fit well? no rubbing? the width between those and the ones i want to run is identical, the only difference is the height, it would be 42 mm overall circumference difference, if you think of the tire as a square, that would be just over ten mm per side. what is the offset and the rim width of the SEI rims?
  3. #53
    Okay, which rims?
    In order from most-favored to least:
    Fits
    Si's
    Fat-Fives
    LS Mesh/Webs
    (all 16's with same offset, right?)
  4. #54
    I'm trying to get these with Bridgestone 185/55's for $335:
    http://images.craigslist.org/3k13pe3...4b33db1f94.jpg
    They're over $2,000 from Honda, without tires. They're from the '10 Fit Sport.
  5. #55
    LX User Importordomestic's Avatar
    1988 Accord Hatch
    Hueytown Alabama
    can someone tell me if 250/60 14 will rub? anyone running them?
    Im running a 225/45/15 with a +35 offset and its retarted close to rubbing.
    i sized the rim to be a 14x9.5 with a +20 mm offset
    yeah it will fit under the car and stick out 2.2 inches farther than the stock 14 rim. But rub probably when you lock to lock the steering wheel. you would have to ru na rim with a +20 or lower offset to get it away from the front knuckes and rear trailing arm.
    http://www.wheelsmaster.com/rt_specs.jsp
    88 - Hatch - FF class track car Major Upgrades!
    87 - Hatch - DD
    88 rx7 turbo II - FR class track car - blown engine
    86 rx7 NA - Under Construction
    90 240 hatch - SOLD
  6. #56
    16s or 15s?
    when i went from 15inch rim to a 16 inch rim i lost performance but i had a better top end speed...maybe it was the tire? but for me 15s are just as good
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    15's seem to be the best compromise between comfort, looks and performance.
    i run 205/50 /15 on mine 3g and 5g Sir and they are great.
    just got some dunlop direzza DZ101's for the Sir in that size and i dont think i'
    ll go backto the kumho's i was running.
    the dunlops are much quieter, more comfortable and have far more grip than the kumho.
    the price may be a bit ore, but well worth it.
    oh, and on a 3g, the speedo is still accurate to within a few km/h
  8. #58
    The Fit has 16's, which are pushing it for my taste. Mike has 17's on his coupe, and they're too much for me.
  9. #59
    Instead of starting a new thread, I'll continue off of this one since it's pretty close to being the same subject.
    Anyone recognize these rims?
  10. #60
    anyone know the offset of deleorean rims? different sizes in front and back, but guess what? they are 4x100
  11. #61
  12. #62
    SE-i Sedan 5 spd
    ...... what is the offset and the rim width of the SEI rims?
    I measured one, but I actually don't know how they measure a wheel's width. Taking a tape across the entire width of the wheel gets 6 5/8". On the inside, the flanges move apart slightly as they go "up," but it would appear that 5 1/2" is the inside width.
  13. #63
    Quote Originally Posted by w261w261 View Post
    when did i mention SEI rims? you could always use two sets of delorean rims from either the front or back, i think the front had a weird offset like a front wheel drive
  14. #64
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    Check post #52.
  15. #65
    ...what the fuck?
  16. #66
    Feb 2003
    NH
    ...what the fuck?
  17. #67
    wat
  18. #68
    This thread got really weird.
  19. #69
    anyone know if a 175-70-15 would fit? if it did if i ever get the freaking money,like an armored truck falls out of the sky, Hoosier quick time DOT drag race tires will fit, they look completely bad ass on old hondas with the big Hoosier in white letters on the sidewall. that was THE tire to run when racing these cars. they are street legal, I just wouldn't want to drive them in the rain.
    according to the tire size calculator the speedo would only be off 3 mph.
  1. tire size
    By import racer in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-24-2007, 11:25 PM
  2. Tire Down Size
    By NoGeezsGap in forum 3geez Accords
    Last Post: 11-06-2006, 07:42 PM
  3. Tire size 17's
    By TWOLOUDNPROUD in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-04-2004, 03:04 PM
  4. Rim/Tire Size
    By troutz15 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-23-2004, 05:33 PM
  5. tire size?
    By dhcarss in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-19-2002, 03:10 PM
