Results 1 to 17 of 17
Thread: Horrible squeaking noise while driving
    DX User A20A1_88Accord's Avatar
    Aug 2009
    Exclamation Horrible squeaking noise while driving
    I have an 88 Accord LX and my my car, on the front right side (passenger side) of the car. it started about 2 weeks ago. It only squeaks when im driving under 30mph or if i hit the brakes while going slower than 30mph. i cant cruise at all because you can hear me coming from a mile away squeaking . i took apart the brakes and found nothing that could be squeaking. does anyone know if this is the brakes or if it is something else? please any advice on how to fix this would be great thanx
    Re: Horrible squeaking noise while driving
    Check the wheel bearing by jacking up that side only and rocking the wheel at the 12 and 6 o clock position. There should be like 0 play. Also check that the big nut is on tight that preloads the bearing. if its sqeeking its shot.
    AZ
    definitely sounds like a wheel bearing.
    dead white and blue
    Dec 2003
    Millington, TN
    I agree, most likely wheel bearing.
    Phil
    SEi User dacantu's Avatar
    Jan 2009
    Phoenix
    bringing back this thread....
    this is exactly whats going on with my ar right now too. im not sure if its the same kind of squeaking but when im accelerating it doesnt do it. It only does it when i release the gas pedal and brakeing. mine is doing it on the front passenger side just as well. when you get out of the car and start to shake the front of it, you can also hear the squeaking just not as loud.
    if it is this bearing that you guys say it is where exactly is it located and how hard is it to repair?
    -dan
    LXi User headbanger's Avatar
    Dec 2007
    1989 accord lxi
    waynesville,nc
    mine is squeaking from passenger side as well an its not the bearing.Heres a list of the stuff I changed trying to fix it an still no good.Lower control arms with bushings,upper control arms with bushings,tie rod ends,upper balljoint, strut,and the axle I have also greased the crap out of everything first with silicone spray then with ball bearing grease still squeaks im going to try lower balljoint next.An if that dont fix it then maybe sway bar bushings not much left to change.lol.GL on urz All wheel bearings I have ever had go out on me grind not squeak dunno though.
    Jan 2009
    Phoenix
    Thanks headbanger,
    I'll try what youre saying, atleast the bushings. I feel like mine might just need new bushing but i have to get in there and take a better look.
    where did you buy your new bushings from?
    -dan
    SE-i Sedan 5 spd
    Before reading most of these posts I would automatically have said either a ball joint or a control arm bushing. Did you use silicone grease on the bushings?
    Nswst8, every wheel bearing that I've had start to go makes a sort of roaring noise, nothing high pitched at all. How would you describe the high pitched sound...like a turbine whine?
    Jan 2009
    Phoenix
    Quote Originally Posted by w261w261 View Post
    i think Nswst8 was on this thread a few months back. I just brought back the thread because i had thee same problem as the original guy..
    but the squeaking sound doesnt sound at all like a turbine, it sounds more like a squeaky dog toy. and thats only when im decelerating. otherwise it does not make the sound. but it is very embarrassing because even my friend even said he heard it when we took our cars to the drag strip. we raced each other a few times and he said he even though it was his car! lol
    -dan
    My first thought is brake pads but maybe you already checked that.
    Jan 2009
    Phoenix
    actually i havent done that recently maybe that wouldnt hurt plus its not too hard to check them so that should be soon
    -dan
    Dec 2007
    1989 accord lxi
    waynesville,nc
    Quote Originally Posted by dacantu View Post
    Thanks headbanger,
    I bought my bushings from ebay despite what people say rubber is rubber it doesnt matter if you get it at the honda dealer or ebay only difference is price.I got 2 lower control arms for 40.00 shipping an all.advance auto parts wanted 125.00 for one so price difference is quite lovely.Yeah best way to describe the squeaking on mine is .....it sounds like a bedspring.You can go out an push up an down on front bumper an it goes reeeeeeeeeeek reeeeek reeeeeeek most annoying thing I turn up stereo an drown it out but i still know its there drives me nutts.it does it while accelerating as well.I will find it.its just a matter time.I ve took the front end apart so many times over the past month I could do it blind folded.
    DX User geej07's Avatar
    Sep 2008
    87 accord lxi rip. 88 lx 89 lxi parts car
    zanesville ohio
    my 88 lx is making the same sound on the driver side. its like a high pitch squeak. an mine does it around 25mph when your going about 40mph its still there just not as noticeable. i was thinkin wheel bearing too. idk.
    I didnt read none of the other post just glanced. BUT sounds like a shim or a clip thats on the caliper bracket. those to to bind up and make that noise. It could also be your dust shield. OR your pads. PAds do have a Tab that tells you WHOAAA MOTHER FUCKER time to stop and change my pads LOL. no but when your 3geez is yelling at you like that. ITS time to charge her pads. LMFAO.
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    [QUOTE=A20A1_88Accord;975396]I have an 88 Accord LX and my my car, on the front right side (passenger side) of the car. it started about 2 weeks ago. It only squeaks when im driving under 30mph or if i hit the brakes while going slower than 30mph. i cant cruise at all because you can hear me coming from a mile away squeaking . i took apart the brakes and found nothing that could be squeaking. does anyone know if this is the brakes or if it is something else? please any advice on how to fix this would be great thanx[/QUOTE
    get new pads man and dont get metallic brake pads those squeal like a motherfucker had same problem and all i did was change them and no squeak had them pads on for 3 months now and still nothing...get the ceramic brake Pads and you should be good for the next 6 months depends if you brake alot
    Sep 2008
    zanesville ohio
    I replaced the brakes on mine an it still does it. Mine kinda sounds like a tire rubbing or cv boot. But I've check an neither of them are rubbing. Ill check out the caliper an see if its touchin the rotar
    I agree
  1. Horrible noise. :( *video
    By Nio in forum 3geez Accords
    Last Post: 04-29-2011, 10:39 PM
  2. werid Squeaking noise from left front
    By alboy86 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-28-2007, 06:32 PM
  3. Horrible gas mileage
    By 86-accord-lxi in forum 3geez Accords
    Last Post: 04-25-2006, 07:24 PM
  4. what a horrible day...
    By AD9SloAccrd in forum Interior & Exterior Care
    Last Post: 05-05-2004, 06:40 PM
  5. This is just horrible
    By shaodome in forum Classic Honda Pics & Videos
    Last Post: 06-28-2002, 08:20 PM
