ya i noticed we strayed pretty badly (and didn't answer the question as to why he dc bar doesn't fit) I would not be opposed to breaking it up
"You may have beat me by .2 seconds but i only spent $2000 on my car, hope that extra $25000 was worth it" My famous last words
tell me what you want it changed to and Ill change it. you answered my question great. It seems to be unanimous that its beter to reinforce the stock situation than add a modifier. Plus I would hate to start cutting into my car. i dont mind changing it. Just let me know. theirs no reason to add more threads just to clutter up the board. Thanks for the help guys and great info in here
it would be great to change the title and remove the clutter posts and make it a sticky for informational purposes.
dead white and blue
alright, it's unanimous... It'll be changed and as stat1k suggested, I'll clean out the poo-poo posts. No sticky yet as this is just theory and not proven application on our specific cars... ...but as soon as we get some of these theories tested and proven, I'll toss a sticky on it.
-Mark D.
I think with the lighter weight of the CRX, 450lb springs in the front should be plenty stiff enough to allow removal the front sway bar without any issues of running out of suspension travel (assuming it's not super-slammed). What kind of temps is he getting across the tires? And what kind of alignment? I would be checking that first. Another cheap way of getting more weight transfer to the rear would be to raise the rear ride height.
I should add that I'm speaking from an autocross perspective, because I'm a poor bastard and that's the only type of motorsports I can afford. On an autocross course, I would say 90% of the time the fastest way around is NOT one that optimizes exit speed. Most of the course is corners linked together, and usually this means hugging the inside to cover the shortest distance and keeping your speed up as much as possible. "In slow, out fast" is kind of the exception to the rule and part of the challenge seems to be finding the few places where it is advantageous to "give it up" because you actually have space to use the exit speed. Not that you drive "In fast, out slow" (or backwards), more like "in medium, out medium, give or take according to what's coming next".
.a also on the front if you have the lude control arms, you can box the control arm with plate steel and make it a lot stronger too.[/QUOTE]
PLEASE EXPLAIN MORE BETTER IM SO CONFUSED AND I CAN PICTURE IT AT ALL IN MY HEAD
