Results 1 to 7 of 7
Thread: Tie-Rod ends, do I need a puller?
    Banned
    Morgantown, West Virginia
    In my front overhaul in little over a week, I am going to be doing the tie-rods. Has anyone used non-genuine tie-rod ends and do I REALLY need a puller? The Haynes says I need one, but the haynes also said I needed a spring compressor to do my suspension.....well technically I did need one...but oh well..4 huge dents in the ceiling later, its done.
    Puller? Yes/no.
    Nate.
    YK86's Avatar
    Oct 2000
    BC, Canada
    I usually use a $10 pickle fork. They will probably tear up the boot on the tierod but since they are being changed anyways, it doesn't matter.
    Also, I always buy Moog suspension stuff including tie rods since they are greaseable. But you need a grease gun to do it.
    www.b20accord.com
    Banned
    The boots are already ripped to hell. I guess I will buy genuine honda stuff since I am ordering sway bar bushings anyway.
    Nate.
    89 Accord LX Coupe
    Vernon BC CANADA
    a puller will work but a pickle fork will probably be cheaper...
    or else use a BFG since you wont be needing them anyway...
    bash to your hearts consent..
    BEn
    Oct 2001
    87 Accord EX , 5spd , Manual
    A BIG HAMMER worked fine with me ! just give it a hit from the side ( while the nut is not all the way out ! ) and it will be out ! i used non genuine and they work fine and much cheaper but they don't last that long ! but they are easy to change !
    MIKE
    SEi User jigga225's Avatar
    Louisiana
    u dont need no puller!
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    no puller or fork. just hit the side of the arm where the tierod end goes into and it will pop out like it is being born again!
    Travis
  1. Wheel bearing puller tool
    By -$MOKIN- in forum 3geez Accords
    Last Post: 08-21-2011, 10:39 PM
  2. inner tie rod ends.
    By TJ89Accord in forum 3geez Accords
    Last Post: 12-15-2003, 02:31 PM
  3. removing ball joint -- can I use gear puller?
    By Greg in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-14-2003, 03:29 PM
  4. best dent puller?
    By sleeper98gsr in forum Interior & Exterior Care
    Last Post: 03-28-2003, 12:13 PM
  5. steering wheel puller?
    By 90CRX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-23-2003, 09:26 PM
